How can we read connection ID of external NFC euipment by PN7150 ?
1,359 次查看
kozonakata
We're using MCU + PN7150 (conncted via I2C) to communicate with external NFC equioment.
We used data packet to send specific command to the NFC equipment, but we failed.
1) We succeeded to recognize the NFC euipment using RF_DISCOVERY_CMD.
2) We sent CORE_CONN_CREATE_CMD to read connection ID (neccesary to send data packet), but response staus=1 (REJECT) was returned.
   So we could not read out connection ID.
Can we hav eany documentation or sample code to read out connection ID ?
Your kind and prompt advice is apprteciated.
Kozo
1,253 次查看
Jonathan_Iglesias
Hi Kozo Nakata,
Hope you are doing great, is it possible you share more information about your project, which MCU, library and library version you are using here?
Have a great day !
Jonathan
1,253 次查看
kozonakata
Dear Jonathan
Thank you for your reply.
But we already found solution based on UM10936.
Please let us ask and explanation for biz if have another question .
Thanks and Best regards,
Kozo Nakata
Technical Solution Manager
Kozo.Nakata@FutureElectronics.com<mailto:Kozo.Nakata@FutureElectronics.com>
+81-80-7691-8594(cellar), +81-45-670-1227(dial-in), +81-45-224-2155(office)
Future Electronics Japan
Yokohama Landmark Tower 30F
Minato Mirai 2-2-1 Nishi-ku,Yokohama,Japan 220-8130
http://www.futureelectronics.co.jp/Default.aspx
