How can I read FeliCa IC card information using PN 7150?
1,675 次查看
改發一輝
I want to read IC card information of FeliCa using PN 7150 referring to NFC Controller Interface (NCI) Specification Version 1.
However, although the polling command is described, since the read command is not described, the realization method is unknown.
help me
标记 (3)
1,394 次查看
Kan_Li
The FeliCa reading is a patent of Sony, please check with Sony for the license.
Kan
