Hi i am porting my device to android Pie, the NFC tags are not being read sometimes, logs show watchdog being triggered. please let me know how can this be resolved. i have attached the logs below
1,124 次查看
onkarchodankar8
In settings the NFC toggle on/off fails to set NFC on after a few times of toggling , after reboot it works normally a few times and then goes to the bad state again. also the tags/cards sometimes are not read. I have analysed the logs and looks like watchdog is being triggered which is causing the failure.
标记 (3)
1 回复
956 次查看
jimmychan
which chip are you using?
