Compared to an LPC1769 or a Kinetis K82, it is a very limited Hardware. If you are looking for an automotive MCU with Higher performance, it would be interesting to take a look to the S32K family:
32-bit Automotive General Purpose MCUs|NXP
Once you find the correct MCU for the porting, it would be helpful to refer to the following document:
NFC Reader Library Porting to i.MX RT1050
I hope this helps.
Ivan.
