HTRC110: Multiple Antennas on Single Reader
abderr
Dear NXP-Community,
To reduce the cost of our RFID reader, we would like to use an HTRC110 to control 2 antennas using a multiplixing system.
I found application note AN11314 which describes how to use a single reader with multiple antennas. But HTRC110 is not mentioned.
I would like to know if it is possible and if so how to do it.
Thank you
Best Regards
nxa24261
Dear Abderrahim,
excellent observation about the NFC Antenna switching circuit.
Unfortunately, it was not designed nor tested for usage with LF, so we cannot assure that it will work for HTRC110.
Thanks for understanding,
David
