Flashing PN7462 over SWD using command line
1,637 次查看
wouterdhondt
Hi all.
Currently we are flashing the PN7462 eeprom and software code using the serial wire debug interface with the LPCXpresso IDE on Windows. We'd like to automate this using a command line utility. Is there any tool available that we can use?
1,325 次查看
Carlos_Mendoza
Hi Wouter,
You can use the LPCXpresso command line flash programming tool:
https://community.nxp.com/message/630785
Hope it helps!
Carlos Mendoza
Technical Support Engineer
