FOR testmod in CLRC663 to measure analog signal.
waynejeong
Hello
We have a problem to get EVMco in type B test. So we want to measure analog signal through AUX1, AUX2.
We can see how to enter testmod and what we can set analog signal which we want to measure with application note(AN11019).
But I am not sure when I must to call the command. Do I have to execute before send request B or type B setting?
If you have a example source code please let me get it. If not, please explain for me the process details.
Thank you
waynejeong
Hello
I have solved this issue using NFC cockpit.
Thank you.
estephania_mart
It is good that you were able to solve it.
You can also check this EMVCo L1 Contactless certification process  maybe it can help through your process.
Estephania
