Do you have a contactless JavaCard chip, but not in the size of a card, somthing much smaller?
841 次查看
DannyGembom
For out application we need a very small contactless JavaCard chip.
All the cards we see  we believe that the chip must need the whole card since it is the Antenna.
Which NXP JavaCard products have a internal antenna on the chip, so we can cut it and it will still work?
Or even better, buy directly the chip outside of thee card.
I have tried to buy JavaCard, and to manually cutting the chip, but when I start cutting the card, the NFC stops working.
I need a small JavaCard. Do you have that?
Why JavaCard? Because we need the Global Platform.
821 次查看
DannyGembom
1. I already filled the NDA. Waiting for it to be approved.
2. I'm asking about which product to choose, also the list of products it under an NDA?
3. Corrently we don't have a distributor yet, since we are still in the R&D stage.  There is a way to be approved without distributer?
794 次查看
Fabian_R
Unfortunately, this product does require an NDA and the support is through a distributor.
Thank you for your patience.
Fabian
825 次查看
Fabian_R
Hello Aminadav,
As you might know,  there are some of the documents and libraries which are under NDA (Non-Disclosure Agreement) and placed in docstore, could you please follow these guides?
Docstore tutorial part 1: User Registration|NXP : https://www.nxp.com/video/docstore-tutorial-part-1-user-registration:DOCSTORE-USER-REGISTRATION
Docstore tutorial part 2: portal usage|NXP :
https://www.nxp.com/video/docstore-tutorial-part-2-portal-usage:DOCSTORE-TUTORIAL-PORTAL-USAGE
Also, you will need to contact one of our distributors available in the  Distributor Network|NXP to help you through the NDA process.
https://www.nxp.com/support/sample-buy/distributor-network:DISTRIBUTORS
Fabian
