Default EEPROM v4.0 of PN5180
TrungDT
Hi Sir,
Can I have an EEPROM default data of PN5180?
I am using PN5180's EEPROM version 4.0
Thanks.
EduardoZamora
Hello @TrungDT
Hope you are doing well.
You can update the firmware of the PN5180 as it programs the memories for user EEPROM and RF configuration with default values. Any previous user configuration will be overwritten.
Eduardo.
TrungDT
Thank @EduardoZamora ,
Based on your suggestion, I found the AN11781 document. But I cannot see anywhere to download the PN5180 firmware file.
Thanks.
EduardoZamora
Hello @TrungDT
Eduardo.
TrungDT
I found it in the Cockpit V4.7.
