Can the NXP CLRC663 send and receive arbitrary APDUs?
1,423 次查看
gcarlson
Can the NXP CLRC663 send and receive arbitrary APDUs?    It seems extremely versatile in the many formats it supports,  but data sheet/ref materials don't explicitly say so, except for a small note that the NFC reader library has options to support this.
Gordy Carlson
标签 (2)
1 回复
1,288 次查看
Kan_Li
Hi Gordy Carlson,
It is an application level issue, since the reader library implements it and supports it, it should work if your application handles the arbitrary APDUs.
Kan
