I get "download error" message at the same point (a few seconds after the downloading starts) everytime . Is it beacuse of the absece of battery?
解決済! 解決策の投稿を見る。
Hi Preenness:
All NHS31XX ICs support both wired and wireless flashing to store the firmware in the non-volatile FLASH memory. Wired flashing uses the JTAG standard over the 2-pin electrical interface SWD. Wireless flashing uses the NDEF protocol over the NFC interface.
Wireless flashing requires a low-ohmic external supply connected to VBAT, Flashing is not possible on VNFC supply only.
Please refer to AN 12328 for more details.
Hi Preenness:
Thank you Daniel, I've got it.
