Dear All,
We use CLRC663, MFRC631, MFRC630, SLRC610.
Please tell me the power sequence of VDD, VDD(PVDD) and VDD(TVDD).
The data sheet has the following description.
VDD(PVDD) must always be the same or lower voltage than VDD.
By the above, I understood the sequence of VDD and VDD (PVDD).
However, VDD (TVDD) does not describe constraints with VDD.
Question:
Is it OK to supply power to VDD (TVDD) when VDD power is supplied or when power is not supplied?
Yasushi Hasegawa
Solved! Go to Solution.
Hello Yasushi,
Weidong sun
Hello Yasushi,
Weidong sun
Dear Wigros Sun,
Thank you for your answer.
Yasushi Hasegawa
Dear Wigros,
I'm sorry to bother you when you are busy, but can you answer about the following?
However, what I want to know is the Power sequence, that is, the order.
I'm sorry to bother you, but please let me ask you the following question again.
Yasushi Hasegawa
Dear Wigros,
Thank you for your prompt response.
Yasushi Hasegawa
