按 https://www.nxp.com.cn/docs/en/application-note/AN13971.pdf 移植
使用 FactoryTestApp DPC Check失败
# ./linux_NfcFactoryTestApp
NFC Factory Test Application
>> 20 00 01 01
<< 40 00 01 00
<< 60 00 09 02 01 20 04 04 61 12 50 05
>> 20 00 01 01
<< 40 00 01 00
>> 20 01 02 00 00
<< 40 01 1e 00 1a 7e 06 02 01 d0 02 ff ff 01 ff 00 08 00 00 01 00 02 00 03 00 80 00 82 00 83 00 84 00
PN7160 NFC controller detected
>> 2f 00 01 00
<< 4f 00 01 00
Select the test to run:
1. Continuous RF ON mode
2. Functional mode
3. PRBS mode
4. Standby mode
5. Dump RF settings
6. Set RF setting
7. Get NCI parameter value
8. Set NCI parameter value
9. Get proprietary parameter value
10. Set proprietary parameter value
11. Get current value
12. DPC Check
13. Get AGC value
14. Get AGC_NFCLD value
15. Dump EEPROM settings
enter 0 to leave the application
Your choice: 12
DPC Check (enter 'ff' during tag ID selection step to leave):
- Enter 00 for DPC Check (hexadecimal): 00
>> 2f 3f 03 03 00 00
<< 4f 3f 01 09
Error, cannot get parameter value NXP VER
byte0 4Fh
byte1 3Fh
Lenght 01h
Status(00h OK) 09h
完整log在附件
部分错误日志如下:
解決済! 解決策の投稿を見る。
