Do not enable RF afterwards, before the hardware is modified properly!
Enabling the RF without supplying the VUP might kill the PN5190/PN7642!
Note: OM27642EVK does not require any jumper settings (DC-DC is not used by default), User only must to disable DC-DC in EEPROM (address 0x0000, value 0x21)
Then you can turn-on RF and perform ULPCD
