Installation of Linux CCID driver For NFC Reader
Recently, some NFC customer want to use CCID driver to communcate with NFC reader on Linux platform, but they encontered some errors during installing CCID driver for linux. I tested it and installed it to ubuntu 16.04 LTS successfully. Let me share complete steps with those users who want to devevlope NFC applications based on linux platform. If we want to use CCID driver on linux, we need to install these packages:
--libusb
--pcsc-lite
--ccid driver
--opensc
Before starting to install above packages, probably we need to install necessary dependency packages:
# sudo apt-get install git-core gnupg flex bison gperf build-essential zip curl zlib1g-dev libc6-dev lib32ncurses5-dev
# sudo apt-get install x11proto-core-dev libx11-dev lib32readline-gplv2-dev lib32z1-dev
# sudo apt-get install libgl1-mesa-dev mingw32 tofrodos python-markdown libxml2-utils xsltproc uuid-dev:i386 liblzo2-dev:i386
# sudo apt-get install gcc-multilib g++-multilib
# sudo apt-get install subversion
# sudo apt-get install openssh-server openssh-client
# sudo apt-get install libudev-dev
# sudo apt-get install openssl
# sudo apt-get install libssl-dev
1. libus installation
(1) Download it from : libusb
File name is libusb-1.0.9.tar.bz2
(2)Decompressing it
# tar jxvf libusb-1.0.9.tar.bz2
# cd ~/ccid/libusb-1.0.9
# ./configure
# make
# sudo make install
(3) test it
# lsusb
2. pcsc-lite installation
(1) Downloading pcsc-lite package: MUSCLE
Filename is : pcsc-lite-1.8.22.tar.bz2
(2) Decompressing it
# tar jxvf pcsc-lite-1.8.22.tar.bz2
(3) compiling it
# cd pcsc-lite-1.8.22
# ./configure
# make
# sudo make install
3. CCID driver installation
(1) Downloading it from : Alioth: Muscle PCSC lite: Project Filelist
file name is : ccid-1.4.27.tar.bz2
# tar jxvf ccid-1.4.27.tar.bz2
(3) Compiling it
# cd ccid-1.4.27
# ./configure
After runing configure command, information below will be displayed:
# make
# sudo make install
4. opensc installation
(1) Downloading it from : OpenSC - Browse /OpenSC/opensc-0.16.0 at SourceForge.net
File name is : opensc-0.16.0.tar.gz
# tar zxvf cd opensc-0.16.0.tar.gz
(3)Compiling it
# cd opensc-0.16.0
# ./configure --enable-openssl --enable-pcsc
# make
# sudo make install
Up to now, above 4 software packages have been installed to ubuntu 16.04 LTS.
(4) Add library file path
   open /etc/ld.so.conf , and add one line at the end of the file :  include /usr/local/lib , save and exit, run 'sudo ldconfig -v' to update it.
# sudo gedit /etc/ld.so.conf
# sudo sudo ldconfig -v
5. Add Vendor ID & Product ID to info.plist
We should add Vendor ID & Product ID of NFC reader to info.plist, the file is at the path : /usr/local/lib/pcsc/drivers/ifd-ccid.bundle/Contents/. For example , PN7462's vendor ID is 0x1FC9, and product ID is 0x0117.
[Note] This requires Firmware on NFC reader board should support USB CCID, if not, customer should replace it with firmware that supports USB CCID, for the purpose, customer can refer to UM10915.pdf(http://www.nxp.com/docs/en/user-guide/UM10915.pdf ) to do it.
TIC team Weidong Sun
コメント
Hello I tried instalation of PN7462 reader but don't work
I have this error :
12280717 hotplug_libudev.c:651:HPEstablishUSBNotifications() USB Device add
00000084 hotplug_libudev.c:297:get_driver() Looking for a driver for VID: 0x1FC9, PID: 0x0117, path: /dev/bus/usb/003/029
00000007 hotplug_libudev.c:436:HPAddDevice() Adding USB device: PN7462 Card Reader
00000029 readerfactory.c:1074:RFInitializeReader() Attempting startup of PN7462 Card Reader (1.00) 00 00 using /usr/local/lib/pcsc/drivers/ifd-ccid.bundle/Contents/Linux/libccid.so
00000104 readerfactory.c:949:RFBindFunctions() Loading IFD Handler 3.0
00000016 ifdhandler.c:1965:init_driver() Driver version: 1.4.28
00000463 ifdhandler.c:1982:init_driver() LogLevel: 0x0003
00000005 ifdhandler.c:1993:init_driver() DriverOptions: 0x0000
00000144 ifdhandler.c:111:CreateChannelByNameOrChannel() Lun: 0, device: usb:1fc9/0117:libudev:0:/dev/bus/usb/003/029
00000011 ccid_usb.c:302:OpenUSBByName() Using: /usr/local/lib/pcsc/drivers/ifd-ccid.bundle/Contents/Info.plist
00000448 ccid_usb.c:320:OpenUSBByName() ifdManufacturerString: Ludovic Rousseau (ludovic.rousseau@free.fr)
00000004 ccid_usb.c:321:OpenUSBByName() ifdProductString: Generic CCID driver
00000002 ccid_usb.c:322:OpenUSBByName() Copyright: This driver is protected by terms of the GNU Lesser General Public License version 2.1, or (at your option) any later version.
00000529 ccid_usb.c:656:OpenUSBByName() Found Vendor/Product: 1FC9/0117 (PN7462 Card Reader)
00000004 ccid_usb.c:658:OpenUSBByName() Using USB bus/device: 3/29
00000002 ccid_usb.c:717:OpenUSBByName() bNumDataRatesSupported is 0
00067645 ccid_usb.c:849:WriteUSB() write failed (3/29): -99 LIBUSB_ERROR_OTHER
00000134 ccid_usb.c:849:WriteUSB() write failed (3/29): -99 LIBUSB_ERROR_OTHER
00000244 ccid_usb.c:888:ReadUSB() read failed (3/29): -99 LIBUSB_ERROR_OTHER
00000006 ifdhandler.c:195:CreateChannelByNameOrChannel() failed
00000023 ccid_usb.c:189:close_libusb_if_needed() libusb_exit
00000015 readerfactory.c:1105:RFInitializeReader() Open Port 0x200000 Failed (usb:1fc9/0117:libudev:0:/dev/bus/usb/003/029)
00000002 readerfactory.c:376:RFAddReader() PN7462 Card Reader (1.00) init failed.
00000003 readerfactory.c:609:RFRemoveReader() UnrefReader() count was: 1
00000003 readerfactory.c:1125:RFUnInitializeReader() Attempting shutdown of PN7462 Card Reader (1.00) 00 00.
00000004 readerfactory.c:986:RFUnloadReader() Unloading reader driver.
00000047 hotplug_libudev.c:523:HPAddDevice() Failed adding USB device: PN7462 Card Reader
What can i do ?
thanks in advance.
ND2
Hello @Wingros Sun
Can you please confirm is the installation instructions that you have provided will work for both contact as well as contactless? or is it just for contact interface?
Neel.
Hello Nell Shah,
    Sorry, I forgot to give user's the procedure of validation, I tested it today again, see below, please!
1. Run lsusb command.
weidong@ubuntu:~$ lsusb
Bus 002 Device 002: ID 0e0f:0003 VMware, Inc. Virtual Mouse
Bus 002 Device 003: ID 0e0f:0002 VMware, Inc. Virtual USB Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 004: ID 0e0f:0008 VMware, Inc.
Bus 002 Device 005: ID 1fc9:0117 NXP Semiconductors
weidong@ubuntu:~$
2. Open 2 terminals on Ubuntu desktop
(1) One is used to run "/usr/local/sbin/pcscd -adf"
weidong@ubuntu:~$ sudo /usr/local/sbin/pcscd -adf
[sudo] password for weidong:
00000000 pcscdaemon.c:345:main() pcscd set to foreground with debug send to stdout
00095256 configfile.l:361:DBGetReaderList() Parsing conf file: /usr/local/etc/reader.conf.d
00000062 pcscdaemon.c:658:main() pcsc-lite 1.8.22 daemon ready.
00020970 hotplug_libudev.c:297:get_driver() Looking for a driver for VID: 0x1D6B, PID: 0x0001, path: /dev/bus/usb/002/001
00000133 hotplug_libudev.c:297:get_driver() Looking for a driver for VID: 0x1D6B, PID: 0x0001, path: /dev/bus/usb/002/001
00000112 hotplug_libudev.c:297:get_driver() Looking for a driver for VID: 0x0E0F, PID: 0x0003, path: /dev/bus/usb/002/002
00000124 hotplug_libudev.c:297:get_driver() Looking for a driver for VID: 0x1D6B, PID: 0x0001, path: /dev/bus/usb/002/001
00000227 hotplug_libudev.c:297:get_driver() Looking for a driver for VID: 0x0E0F, PID: 0x0002, path: /dev/bus/usb/002/003
00000175 hotplug_libudev.c:297:get_driver() Looking for a driver for VID: 0x0E0F, PID: 0x0008, path: /dev/bus/usb/002/004
00000110 hotplug_libudev.c:297:get_driver() Looking for a driver for VID: 0x0E0F, PID: 0x0008, path: /dev/bus/usb/002/004
00000142 hotplug_libudev.c:297:get_driver() Looking for a driver for VID: 0x0E0F, PID: 0x0002, path: /dev/bus/usb/002/003
00000094 hotplug_libudev.c:297:get_driver() Looking for a driver for VID: 0x1FC9, PID: 0x0117, path: /dev/bus/usb/002/005
00000016 hotplug_libudev.c:436:HPAddDevice() Adding USB device: PN7462 USB Reader
00000048 readerfactory.c:1074:RFInitializeReader() Attempting startup of PN7462 USB Reader (1.00) 00 00 using /usr/local/lib/pcsc/drivers/ifd-ccid.bundle/Contents/Linux/libccid.so
00035459 readerfactory.c:949:RFBindFunctions() Loading IFD Handler 3.0
00000140 ifdhandler.c:1965:init_driver() Driver version: 1.4.27
00000452 ifdhandler.c:1982:init_driver() LogLevel: 0x0003
00000016 ifdhandler.c:1993:init_driver() DriverOptions: 0x0000
00000185 ifdhandler.c:111:CreateChannelByNameOrChannel() Lun: 0, device: usb:1fc9/0117:libudev:0:/dev/bus/usb/002/005
00000087 ccid_usb.c:302:OpenUSBByName() Using: /usr/local/lib/pcsc/drivers/ifd-ccid.bundle/Contents/Info.plist
00000387 ccid_usb.c:320:OpenUSBByName() ifdManufacturerString: Ludovic Rousseau (ludovic.rousseau@free.fr)
00000016 ccid_usb.c:321:OpenUSBByName() ifdProductString: Generic CCID driver
00000024 ccid_usb.c:322:OpenUSBByName() Copyright: This driver is protected by terms of the GNU Lesser General Public License version 2.1, or (at your option) any later version.
00000375 ccid_usb.c:656:OpenUSBByName() Found Vendor/Product: 1FC9/0117 (PN7462 USB Reader)
00000026 ccid_usb.c:658:OpenUSBByName() Using USB bus/device: 2/5
00382852 ifdhandler.c:382:IFDHGetCapabilities() tag: 0xFB3, usb:1fc9/0117:libudev:0:/dev/bus/usb/002/005 (lun: 0)
00000024 readerfactory.c:396:RFAddReader() Using the reader polling thread
00003700 ifdhandler.c:382:IFDHGetCapabilities() tag: 0xFAE, usb:1fc9/0117:libudev:0:/dev/bus/usb/002/005 (lun: 0)
00000008 ifdhandler.c:477:IFDHGetCapabilities() Reader supports 1 slot(s)
00000178 hotplug_libudev.c:297:get_driver() Looking for a driver for VID: 0x0E0F, PID: 0x0002, path: /dev/bus/usb/002/003
00000212 hotplug_libudev.c:297:get_driver() Looking for a driver for VID: 0x1D6B, PID: 0x0002, path: /dev/bus/usb/001/001
00000090 readerfactory.c:1409:RFWaitForReaderInit() Waiting init for reader: PN7462 USB Reader (1.00) 00 00
(2) The other is used to run "testpcsc " in pcsc-lite/src source code
weidong@ubuntu:~/ccid/pcsc-lite-1.8.22/src$ ./testpcsc
MUSCLE PC/SC Lite unitary test Program
THIS PROGRAM IS NOT DESIGNED AS A TESTING TOOL FOR END USERS!
Do NOT use it unless you really know what you do.
Testing SCardEstablishContext    : Command successful.
Testing SCardIsValidContext    : Command successful.
Testing SCardIsValidContext    : Invalid handle. (don't panic)
Testing SCardListReaderGroups    : Command successful.
Group 01: SCard$DefaultReaders
Testing SCardFreeMemory        : Command successful.
Testing SCardListReaders    : Command successful.
Reader 01: PN7462 USB Reader (1.00) 00 00
[Note] if you are using vmware player on your windows PC, don't forget to connect PN7462 board to ubuntu, see below, please!
Have a nice day!
Weidong
Hello Neel,
       The firmware for PN7462 DEMO BOARD must be released version,  not debug version.
Have a nice day!
weidong
ND2
Hi Wingros,
Are you used the phExCCID example code for the PN7462AU?
Can you please share exactly the firmware file you are using? Did you modify the firmware file for running it on the Linux environment?
We are NOT able to see the PN7462AU in the lsusb command. I can send you a screenshot if you'd like.
At the same time we are able to see the ACR contact reader there.
Neel.
P.S. Will the same instructions work for a UNIX operating system as well? Do you have any idea about that?
ND2
Hi Wingros,
The USB card reader has been connected. It has a SAM inserted as well as a DESFire card on the antenna.
Not sure why the SCardListReaders is saying: "Cannot find a smart card reader."
Please suggest.
Neel.
Hi, Neel,
     You shoud follow steps introduced in UM10915.pdf, compile source code with released mode , then download it to demo board.
Weidong
ND2
We know what is released mode Wingros.
Our board has the release mode firmware as suggested in the UM10915.pdf
Not sure still why the driver for the USB is not getting picked up by the OS.
Neel.
Neel Shah.
That is right! Please check 3.6 Release mode setup in UM10915 as well.
Kan
%3CLINGO-SUB%20id%3D%22lingo-sub-1116321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ENFC%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E7%94%A8%E3%81%AELinuxCCID%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116321%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E6%9C%80%E8%BF%91%E3%80%81%E4%B8%80%E9%83%A8%E3%81%AENFC%E3%81%AE%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AF%E3%80%81CCID%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6Linux%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E4%B8%8A%E3%81%AENFC%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%81%A8%E9%80%9A%E4%BF%A1%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E8%80%83%E3%81%88%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81Linux%E7%94%A8%E3%81%AECCID%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E4%B8%AD%E3%81%AB%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%A6%E3%80%81ubuntu%2016.04LTS%E3%81%AB%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82Linux%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%AB%E5%9F%BA%E3%81%A5%E3%81%84%E3%81%A6NFC%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%96%8B%E7%99%BA%E3%81%97%E3%81%9F%E3%81%84%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%A8%E5%AE%8C%E5%85%A8%E3%81%AA%E6%89%8B%E9%A0%86%E3%82%92%E5%85%B1%E6%9C%89%E3%81%95%E3%81%9B%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82Linux%E3%81%A7CCID%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E--libusb%3C%2FP%3E%3CP%3E--pcsc-lite%3C%2FP%3E%3CP%3E--ccid%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FP%3E%3CP%3E--opensc%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB%E3%80%81%E3%81%8A%E3%81%9D%E3%82%89%E3%81%8F%E5%BF%85%E8%A6%81%E3%81%AA%E4%BE%9D%E5%AD%98%E9%96%A2%E4%BF%82%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%23%20sudo%20apt-get%20install%20git-core%20gnupg%20flex%20bison%20gperf%20build-essential%20zip%20curl%20zlib1g-dev%20libc6-dev%20lib32ncurses5-dev%3C%2FP%3E%3CP%3E%23%20sudo%20apt-get%20install%20x11proto-core-dev%20libx11-dev%20lib32readline-gplv2-dev%20lib32z1-dev%3C%2FP%3E%3CP%3E%23%20sudo%20apt-get%20install%20libgl1-mesa-dev%20mingw32%20tofrodos%20python-markdown%20libxml2-utils%20xsltproc%20uuid-dev%3Ai386%20liblzo2-dev%3Ai386%3C%2FP%3E%3CP%3E%23%20sudo%20apt-get%20gcc-multilib%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%20g%2B%2B-multilib%3C%2FP%3E%3CP%3E%23%20sudo%20apt-get%20subversion%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%23%20sudo%20apt-get%20openssh-server%20openssh-client%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%23%20sudo%20apt-get%20install%20libudev-dev%3C%2FP%3E%3CP%3E%23%20sudo%20apt-get%20openssl%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E%23%20sudo%20apt-get%20install%20libssl-dev%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2022px%3B%22%3E%3CSTRONG%3E1.%20Libus%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E(1)%3C%2FSTRONG%3E%20%3CA%20class%3D%22link-titled%22%20href%3D%22http%3A%2F%2Fwww.libusb.org%22%20title%3D%22http%3A%2F%2Fwww.libusb.org%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Elibusb%3C%2FA%3E%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%20%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%90%8D%E3%81%AF%20%3CSTRONG%3E%3CEM%3Elibusb-1.0.9.tar.bz2%3C%2FEM%3E%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E(2)%E8%A7%A3%E5%87%8D%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CEM%3E%23%20tar%20jxvf%20libusb-1.0.9.tar.bz2%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CEM%3E%23%20cd%20~%2Fccid%2Flibusb-1.0.9%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%23%20.%2Fconfigure%3C%2FEM%3E%3CBR%20%2F%3E%3CEM%3E%23%20%E4%BD%9C%E3%82%8B%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_15.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_15.png%22%20style%3D%22width%3A%20698px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F25239i8A9D91D1454B3CAB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_15.png%22%20alt%3D%22pastedImage_15.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CEM%3E%23%20sudo%20make%20install%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%3C%2FEM%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_16.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_16.png%22%20style%3D%22width%3A%20887px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F25353iA1B4A6D533854B0D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_16.png%22%20alt%3D%22pastedImage_16.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E(3)%E3%83%86%E3%82%B9%E3%83%88%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%23LSUSB%E3%81%AE%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_24.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_24.png%22%20style%3D%22width%3A%20634px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F25242i7ABD355FAA6C2484%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_24.png%22%20alt%3D%22pastedImage_24.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2022px%3B%22%3E%3CSTRONG%3E2.%20PCSC-Lite%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3CBR%20%2F%3E%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E(1)%20pcsc-lite%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%3C%2FSTRONG%3E%3A%20%3CA%20class%3D%22link-titled%22%20href%3D%22http%3A%2F%2Fpcsclite.alioth.debian.org%2F%22%20title%3D%22http%3A%2F%2Fpcsclite.alioth.debian.org%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EMUSCLE%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%90%8D%20%3A%20pcsc-lite-1.8.22.tar.bz2%3C%2FP%3E%3CP%3E%3CSTRONG%3E(2)%E8%A7%A3%E5%87%8D%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%23%20tar%20jxvf%20pcsc-lite-1.8.22.tar.bz2%26nbsp%3B%3C%2FP%3E%3CP%3E%3CSTRONG%3E(3)%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%23%20cd%20pcsc-lite-1.8.22%3CBR%20%2F%3E%23%20.%2Fconfigure%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_29.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_29.png%22%20style%3D%22width%3A%20735px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F25400iC0522FBE807D42EF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_29.png%22%20alt%3D%22pastedImage_29.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_30.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_30.png%22%20style%3D%22width%3A%20976px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F25401i20212CB75F9E776D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_30.png%22%20alt%3D%22pastedImage_30.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%23%20make%20%3C%2FP%3E%3CP%3E...%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_31.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_31.png%22%20style%3D%22width%3A%20781px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F25437iF883BC39BFCBBCFE%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_31.png%22%20alt%3D%22pastedImage_31.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%23%20sudo%20make%20install%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E...%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_32.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_32.png%22%20style%3D%22width%3A%20914px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F25492i6FD39BF6C15D4781%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_32.png%22%20alt%3D%22pastedImage_32.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2022px%3B%22%3E%3CSTRONG%3E3.%20CCID%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E(1)%20%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E5%85%83%3C%2FSTRONG%3E%20%3A%20%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Falioth.debian.org%2Ffrs%2F%3Fgroup_id%3D30105%23title_ccid%22%20title%3D%22https%3A%2F%2Falioth.debian.org%2Ffrs%2F%3Fgroup_id%3D30105%23title_ccid%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EAlioth%3AMuscle%20PCSC%20lite%3A%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E4%B8%80%E8%A6%A7%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%90%8D%20%3A%20ccid-1.4.27.tar.bz2%3C%2FP%3E%3CP%3E%3CSTRONG%3E(2)%E8%A7%A3%E5%87%8D%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%23%20tar%20jxvf%20ccid-1.4.27.tar.bz2%3C%2FP%3E%3CP%3E%3CSTRONG%3E(3)%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%23%20cd%20ccid-1.4.27%3CBR%20%2F%3E%23%20.%2Fconfigure%3C%2FP%3E%3CP%3Econfigure%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%83%85%E5%A0%B1%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E...%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_37.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_37.png%22%20style%3D%22width%3A%20703px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F25587i434B220B88C833F0%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_37.png%22%20alt%3D%22pastedImage_37.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%23%20make%3C%2FP%3E%3CP%3E...%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_38.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_38.png%22%20style%3D%22width%3A%20682px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F25619i42288CE076465568%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_38.png%22%20alt%3D%22pastedImage_38.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%23%20sudo%20make%20install%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E...%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_39.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_39.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F25354i8DF2A3FB9B07EC11%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_39.png%22%20alt%3D%22pastedImage_39.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2022px%3B%22%3E%3CSTRONG%3E4.%20Opensc%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E(1)%20%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E5%85%83%3C%2FSTRONG%3E%20%3A%20%3CA%20class%3D%22link-titled%22%20href%3D%22https%3A%2F%2Fsourceforge.net%2Fprojects%2Fopensc%2Ffiles%2FOpenSC%2Fopensc-0.16.0%2F%22%20title%3D%22https%3A%2F%2Fsourceforge.net%2Fprojects%2Fopensc%2Ffiles%2FOpenSC%2Fopensc-0.16.0%2F%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EOpenSC%20-%20%2FOpenSC%2Fopensc-0.16.0%20at%20SourceForge.net%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CP%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%90%8D%20%3A%20opensc-0.16.0.tar.gz%3C%2FP%3E%3CP%3E%3CSTRONG%3E(2)%E8%A7%A3%E5%87%8D%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%23tar%20zxvf%20cd%20opensc-0.16.0.tar.gz%3C%2FP%3E%3CP%3E%3CSTRONG%3E(3)%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%23%20cd%20opensc-0.16.0%3C%2FP%3E%3CP%3E%23%20.%2Fconfigure--enable-openssl%20--enable-pcsc%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_44.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_44.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F25662iF8D2EC16DD38788B%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_44.png%22%20alt%3D%22pastedImage_44.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%23%20make%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_45.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_45.png%22%20style%3D%22width%3A%20748px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F25620iE2219E7824764092%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_45.png%22%20alt%3D%22pastedImage_45.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%23%20sudo%20make%20install%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_47.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_47.png%22%20style%3D%22width%3A%20716px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F25691i17908506FEDD0896%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_47.png%22%20alt%3D%22pastedImage_47.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%BE%E3%81%A7%E3%81%AB%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE4%E3%81%A4%E3%81%AE%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%8Cubuntu%2016.04LTS%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E(4)%20%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%83%91%E3%82%B9%E3%82%92%E8%BF%BD%E5%8A%A0%3C%2FP%3E%3CP%3E%2Fetc%2Fld.so.conf%20%E3%82%92%E9%96%8B%E3%81%8D%E3%80%81%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E6%9C%AB%E5%B0%BE%E3%81%AB%201%20%E8%A1%8C%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%81%BE%E3%81%99%3A%20include%20%2Fusr%2Flocal%2Flib%20%E3%80%81%E4%BF%9D%E5%AD%98%E3%81%97%E3%81%A6%E7%B5%82%E4%BA%86%E3%81%97%E3%80%81'sudo%20ldconfig%20-v'%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%23%20sudo%20gedit%20%2Fetc%2Fld.so.conf%26nbsp%3B%3C%2FP%3E%3CP%3E%23%20sudo%20sudo%20ldconfig%20-v%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22font-size%3A%2022px%3B%22%3E%3CSTRONG%3E5.%20%E3%83%99%E3%83%B3%E3%83%80%E3%83%BCID%E3%81%A8%E8%A3%BD%E5%93%81ID%E3%82%92info.plist%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%3C%2FSTRONG%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3ENFC%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE%E3%83%99%E3%83%B3%E3%83%80%E3%83%BCID%E3%81%A8%E8%A3%BD%E5%93%81ID%E3%82%92info.plist%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E3%83%91%E3%82%B9%2Fusr%2Flocal%2Flib%2Fpcsc%2Fdrivers%2Fifd-ccid.bundle%2FContents%2F%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81PN7462%20%E3%81%AE%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC%20ID%20%E3%81%AF%200x1FC9%20%E3%81%A7%E3%80%81%E8%A3%BD%E5%93%81%20ID%20%E3%81%AF%200x0117%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%5B%E5%8F%82%E8%80%83%5D%3C%2FSTRONG%3E%20%E3%81%93%E3%82%8C%E3%81%AB%E3%81%AF%E3%80%81NFC%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%E4%B8%8A%E3%81%AE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8CUSB%20CCID%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%81%86%E3%81%A7%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E9%A1%A7%E5%AE%A2%E3%81%AFUSB%20CCID%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E7%BD%AE%E3%81%8D%E6%8F%9B%E3%81%88%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%20%3CA%20class%3D%22link-titled%22%20href%3D%22http%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FUM10915.pdf%22%20title%3D%22http%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FUM10915.pdf%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fuser-guide%2FUM10915.pdf%3C%2FA%3E%20UM10915.pdf%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ETIC%E3%83%81%E3%83%BC%E3%83%A0%20%E3%82%A6%E3%82%A7%E3%82%A4%E3%83%89%E3%83%B3%E3%83%BB%E3%82%B5%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ANFC%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E7%94%A8%E3%81%AELinux%20CCID%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%9D%E3%81%86%E3%81%A7%E3%81%99%EF%BC%81UM10915%E3%81%AE3.6%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%82%82%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E8%89%AF%E3%81%84%E6%97%A5%E3%82%92%E3%81%8A%E9%81%8E%E3%81%94%E3%81%97%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CBR%20%2F%3E%E8%8F%85%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116329%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ANFC%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E7%94%A8%E3%81%AELinux%20CCID%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116329%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AEWingros%E3%81%8C%E4%BD%95%E3%81%A7%E3%81%82%E3%82%8B%E3%81%8B%E3%82%92%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E7%A4%BE%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF%E3%80%81UM10915.pdf%E3%81%A7%E6%8F%90%E6%A1%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EUSB%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8COS%E3%81%AB%E5%8F%96%E5%BE%97%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E7%90%86%E7%94%B1%E3%81%AF%E3%81%BE%E3%81%A0%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENeel.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E--%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%8B%E3%83%BC%E3%83%AB%E3%83%BB%E3%82%B7%E3%83%A3%E3%83%BC%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116328%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ANFC%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E7%94%A8%E3%81%AELinux%20CCID%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116328%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%2C%20Neel%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EUM10915.pdf%E3%81%A7%E7%B4%B9%E4%BB%8B%E3%81%97%E3%81%9F%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%80%81%E3%83%87%E3%83%A2%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EWeidong%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116327%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ANFC%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E7%94%A8%E3%81%AELinux%20CCID%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116327%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.jpg%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64941i162865CE55A8A090%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.jpg%22%20alt%3D%22pastedImage_1.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EHi%20Wingros%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EUSB%E3%82%AB%E3%83%BC%E3%83%89%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%81%8C%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82SAM%E3%81%8C%E6%8C%BF%E5%85%A5%E3%81%95%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81%E3%82%A2%E3%83%B3%E3%83%86%E3%83%8A%E3%81%AB%E3%81%AFDESFire%E3%82%AB%E3%83%BC%E3%83%89%E3%81%8C%E6%8C%BF%E5%85%A5%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESCardListReaders%20%E3%81%8C%20%22%E3%82%B9%E3%83%9E%E3%83%BC%E3%83%88%20%E3%82%AB%E3%83%BC%E3%83%89%20%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%22%20%E3%81%A8%E8%A8%80%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E7%90%86%E7%94%B1%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%94%E6%8F%90%E6%A1%88%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENeel.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116326%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ANFC%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E7%94%A8%E3%81%AELinux%20CCID%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116326%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Wingros%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPN7462AU%E3%81%ABphExCCID%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%AD%A3%E7%A2%BA%E3%81%AB%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3FLinux%E7%92%B0%E5%A2%83%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3Elsusb%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A7PN7462AU%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%88%E3%82%8D%E3%81%97%E3%81%91%E3%82%8C%E3%81%B0%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%BC%E3%83%B3%E3%82%B7%E3%83%A7%E3%83%83%E3%83%88%E3%82%92%E3%81%8A%E9%80%81%E3%82%8A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E5%90%8C%E6%99%82%E3%81%AB%E3%80%81%E3%81%9D%E3%81%93%E3%81%ABACR%E3%82%B3%E3%83%B3%E3%82%BF%E3%82%AF%E3%83%88%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%81%8C%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENeel.%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E8%BF%BD%E4%BC%B8%E5%90%8C%E3%81%98%E6%89%8B%E9%A0%86%E3%81%8CUNIX%E3%82%AA%E3%83%9A%E3%83%AC%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%A7%E3%82%82%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E4%BD%95%E3%81%8B%E8%80%83%E3%81%88%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ANFC%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E7%94%A8%E3%81%AELinux%20CCID%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116325%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%20Neel%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EPN7462%20DEMO%20BOARD%E3%81%AE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%80%81%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%82%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%81%84%E4%B8%80%E6%97%A5%E3%82%92%EF%BC%81%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Eweidong%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ANFC%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E7%94%A8%E3%81%AELinux%20CCID%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%20Nell%20Shah%2C%3C%2FP%3E%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AF%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%81%AB%E6%A4%9C%E8%A8%BC%E3%81%AE%E6%89%8B%E9%A0%86%E3%82%92%E4%B8%8E%E3%81%88%E3%82%8B%E3%81%AE%E3%82%92%E5%BF%98%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E7%A7%81%E3%81%AF%E4%BB%8A%E6%97%A5%E5%86%8D%E3%81%B3%E3%81%9D%E3%82%8C%E3%82%92%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E4%BB%A5%E4%B8%8B%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%81%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99!%3C%2FP%3E%3CP%3E---------------------------------------------------------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E%3CSTRONG%3E1.%20lsusb%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Eweidong%40ubuntu%3A~%24%20lsusb%3CBR%20%2F%3E%E3%83%90%E3%82%B9002%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9002%3AID%200e0f%3A0003%20VMware%E3%80%81Inc.%E4%BB%AE%E6%83%B3%E3%83%9E%E3%82%A6%E3%82%B9%3CBR%20%2F%3E%E3%83%90%E3%82%B9002%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9003%3AID%200e0f%3A0002%20VMware%2C%20Inc.%20%E4%BB%AE%E6%83%B3USB%E3%83%8F%E3%83%96%3CBR%20%2F%3E%E3%83%90%E3%82%B9001%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9001%3AID%201d6b%3A0002%20Linux%20Foundation2.0%E3%83%AB%E3%83%BC%E3%83%88%E3%83%8F%E3%83%96%3CBR%20%2F%3E%E3%83%90%E3%82%B9002%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9001%3AID%201d6b%3A0001%20Linux%20Foundation1.1%E3%83%AB%E3%83%BC%E3%83%88%E3%83%8F%E3%83%96%3CBR%20%2F%3E%E3%83%90%E3%82%B9%20002%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%20004%3A%20ID%200e0f%3A0008%20VMware%2C%20Inc.%20%3CBR%20%2F%3E%E3%83%90%E3%82%B9002%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9005%3AID%20%3CSTRONG%3E1fc9%3A0117%3C%2FSTRONG%3E%20NXP%E3%82%BB%E3%83%9F%E3%82%B3%E3%83%B3%E3%83%80%E3%82%AF%E3%82%BF%E3%83%BC%E3%82%BA%20%3CBR%20%2F%3E%3CA%20href%3D%22mailto%3Aweidong%40ubuntu%3A~%24%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eweidong%40ubuntu%3A~%24%20%3C%2FA%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_5.png%22%20style%3D%22width%3A%20754px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64907i8C6507CD7DCC22DA%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_5.png%22%20alt%3D%22pastedImage_5.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E2.Ubuntu%E3%83%87%E3%82%B9%E3%82%AF%E3%83%88%E3%83%83%E3%83%97%E3%81%A72%E3%81%A4%E3%81%AE%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%82%92%E9%96%8B%E3%81%8D%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E(1)%201%E3%81%A4%E3%81%AF%E3%80%8C%2Fusr%2Flocal%2Fsbin%2Fpcscd%20-adf%E3%80%8D%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Eweidong%40ubuntu%3A~%24%20sudo%20%2Fusr%2Flocal%2Fsbin%2Fpcscd%20-adf%3CBR%20%2F%3E%5Bsudo%5DWeidong%E3%81%AE%E3%83%91%E3%82%B9%E3%83%AF%E3%83%BC%E3%83%89%3A%20%3CBR%20%2F%3E00000000%20pcscdaemon.c%3A345%3Amain()pcscd%20%E3%82%92%E3%83%95%E3%82%A9%E3%82%A2%E3%82%B0%E3%83%A9%E3%82%A6%E3%83%B3%E3%83%89%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%80%81debug%20send%20to%20stdout%3CBR%20%2F%3E00095256%20configfile.l%3A361%3ADBGetReaderList()%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E8%A7%A3%E6%9E%90%3A%20%2Fusr%2Flocal%2Fetc%2Freader.conf.d%3CBR%20%2F%3E00000062%20pcscdaemon.c%3A658%3Amain()pcsc-lite%201.8.22%20%E3%83%87%E3%83%BC%E3%83%A2%E3%83%B3%E5%AF%BE%E5%BF%9C%E3%80%82%3CBR%20%2F%3E00020970%20hotplug_libudev.c%3A297%3Aget_driver()VID%3A0x1D6B%E3%80%81PID%3A0x0001%E3%80%81%E3%83%91%E3%82%B9%3A%2F%20dev%20%2F%20bus%20%2F%20usb%20%2F%20002%2F001%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E00000133%20hotplug_libudev.c%3A297%3Aget_driver()VID%3A0x1D6B%E3%80%81PID%3A0x0001%E3%80%81%E3%83%91%E3%82%B9%3A%2F%20dev%20%2F%20bus%20%2F%20usb%20%2F%20002%2F001%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E00000112%20hotplug_libudev.c%3A297%3Aget_driver()VID%3A0x0E0F%E3%80%81PID%3A0x0003%E3%80%81%E3%83%91%E3%82%B9%3A%2F%20dev%20%2F%20bus%20%2F%20usb%20%2F%20002%2F002%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E00000124%20hotplug_libudev.c%3A297%3Aget_driver()VID%3A0x1D6B%E3%80%81PID%3A0x0001%E3%80%81%E3%83%91%E3%82%B9%3A%2F%20dev%20%2F%20bus%20%2F%20usb%20%2F%20002%2F001%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E00000227%20hotplug_libudev.c%3A297%3Aget_driver()VID%3A0x0E0F%E3%80%81PID%3A0x0002%E3%80%81%E3%83%91%E3%82%B9%3A%2F%20dev%20%2F%20bus%20%2F%20usb%20%2F%20002%2F003%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E00000175%20hotplug_libudev.c%3A297%3Aget_driver()VID%3A0x0E0F%E3%80%81PID%3A0x0008%E3%80%81%E3%83%91%E3%82%B9%3A%2F%20dev%20%2F%20bus%20%2F%20usb%20%2F%20002%2F004%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E00000110%20hotplug_libudev.c%3A297%3Aget_driver()VID%3A0x0E0F%E3%80%81PID%3A0x0008%E3%80%81%E3%83%91%E3%82%B9%3A%2F%20dev%20%2F%20bus%20%2F%20usb%20%2F%20002%2F004%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E00000142%20hotplug_libudev.c%3A297%3Aget_driver()VID%3A0x0E0F%E3%80%81PID%3A0x0002%E3%80%81%E3%83%91%E3%82%B9%3A%2F%20dev%20%2F%20bus%20%2F%20usb%20%2F%20002%2F003%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E00000094%20hotplug_libudev.c%3A297%3Aget_driver()VID%3A0x1FC9%E3%80%81PID%3A0x0117%E3%80%81%E3%83%91%E3%82%B9%3A%2F%20dev%20%2F%20bus%20%2F%20usb%20%2F%20002%2F005%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E00000016%20hotplug_libudev.c%3A436%3AHPAddDevice()USB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E8%BF%BD%E5%8A%A0%3APN7462USB%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%3CBR%20%2F%3E00000048%20readerfactory.c%3A1074%3ARFInitializeReader()%2Fusr%2Flocal%2Flib%2Fpcsc%2Fdrivers%2Fifd-ccid.bundle%2FContents%2FLinux%2Flibccid.so%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20PN7462%20USB%20Reader%20(1.00)%2000%2000%20%E3%82%92%E8%B5%B7%E5%8B%95%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3Ereaderfactory.c%3A949%3ARFBindFunctions()00035459IFD%20%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%203.0%20%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%3CBR%20%2F%3E00000140%20ifdhandler.c%3A1965%3Ainit_driver()%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A1.4.27%3CBR%20%2F%3E00000452%20ifdhandler.c%3A1982%3Ainit_driver()%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%99%E3%83%AB%3A0x0003%3CBR%20%2F%3E00000016%20ifdhandler.c%3A1993%3Ainit_driver()%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%3A0x0000%3CBR%20%2F%3E00000185%20ifdhandler.c%3A111%3ACreateChannelByNameOrChannel()Lun%3A0%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3Ausb%3A1fc9%2F0117%3Alibudev%3A0%3A%2Fdev%2Fbus%2Fusb%2F002%2F005%3CBR%20%2F%3E00000087%20ccid_usb.c%3A302%3AOpenUSBByName()%E4%BD%BF%E7%94%A8%3A%20%2Fusr%2Flocal%2Flib%2Fpcsc%2Fdrivers%2Fifd-ccid.bundle%2FContents%2FInfo.plist%3CBR%20%2F%3E%3CSPAN%3E00000387%20ccid_usb.c%3A320%3AOpenUSBByName()%20ifdManufacturerString%3A%20Ludovic%20Rousseau%20(%3C%2FSPAN%3E%3CA%20class%3D%22jive-link-email-small%22%20href%3D%22mailto%3Aludovic.rousseau%40free.fr%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3Eludovic.rousseau%40free.fr%3C%2FA%3E%3CSPAN%3E)%3C%2FSPAN%3E%3CBR%20%2F%3E00000016%20ccid_usb.c%3A321%3AOpenUSBByName()ifdProductString%3A%20%E6%B1%8E%E7%94%A8%20CCID%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%3CBR%20%2F%3E00000024%20ccid_usb.c%3A322%3AOpenUSBByName()%E8%91%97%E4%BD%9C%E6%A8%A9%3A%20%E3%81%93%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%80%81GNU%20Lesser%20General%20Public%20License%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.1%20%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%9D%E3%82%8C%E4%BB%A5%E9%99%8D%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%20(%E4%BB%BB%E6%84%8F)%20%E3%81%AE%E6%9D%A1%E9%A0%85%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E4%BF%9D%E8%AD%B7%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E00000375%20ccid_usb.c%3A656%3AOpenUSBByName()%E8%A6%8B%E3%81%A4%E3%81%8B%E3%81%A3%E3%81%9F%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC%2F%E8%A3%BD%E5%93%81%3A%201FC9%2F0117%20(PN7462%20USB%20%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC)%3CBR%20%2F%3E00000026%20ccid_usb.c%3A658%3AOpenUSBByName()USB%E3%83%90%E3%82%B9%2F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E4%BD%BF%E7%94%A8%E6%99%82%3A2%2F5%3CBR%20%2F%3E00000002%20ccid_usb.c%3A717%3AOpenUSBByName()bNumDataRatesSupported%20%E3%81%AF%200%20%E3%81%A7%E3%81%99%3CBR%20%2F%3E00382852%20ifdhandler.c%3A382%3AIFDHGetCapabilities()%E3%82%BF%E3%82%B0%3A%200xFB3%2C%20usb%3A1fc9%2F0117%3Alibudev%3A0%3A%2Fdev%2Fbus%2Fusb%2F002%2F005%20(LUN%3A%200)%3CBR%20%2F%3E00000024%20readerfactory.c%3A396%3ARFAddReader()%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%81%AE%E4%BD%BF%E7%94%A8%3CBR%20%2F%3E00003700%20ifdhandler.c%3A382%3AIFDHGetCapabilities()%E3%82%BF%E3%82%B0%3A%200xFAE%2C%20usb%3A1fc9%2F0117%3Alibudev%3A0%3A%2Fdev%2Fbus%2Fusb%2F002%2F005%20(LUN%3A%200)%3CBR%20%2F%3E00000008%20ifdhandler.c%3A477%3AIFDHGetCapabilities()%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AF1%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E00000178%20hotplug_libudev.c%3A297%3Aget_driver()VID%3A0x0E0F%E3%80%81PID%3A0x0002%E3%80%81%E3%83%91%E3%82%B9%3A%2F%20dev%20%2F%20bus%20%2F%20usb%20%2F%20002%2F003%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E00000212%20hotplug_libudev.c%3A297%3Aget_driver()VID%3A0x1D6B%E3%80%81PID%3A0x0002%E3%80%81%E3%83%91%E3%82%B9%3A%2F%20dev%20%2F%20bus%20%2F%20usb%20%2F%20001%2F001%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E00000090%20readerfactory.c%3A1409%3ARFWaitForReaderInit()%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E5%BE%85%E3%81%A1%3APN7462%20USB%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC(1.00)00%2000%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_9.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64912iA00B5DBAE7AFF85E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_9.png%22%20alt%3D%22pastedImage_9.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E(2)%20%E3%82%82%E3%81%86%E4%B8%80%E3%81%A4%E3%81%AF%E3%80%81pcsc-lite%2Fsrc%20%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%20%22testpcsc%22%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3Eweidong%40ubuntu%3A~%2Fccid%2Fpcsc-lite-1.8.22%2Fsrc%24%20.%2Ftestpcsc%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EMUSCLE%20PC%2FSC%20Lite%20%E3%83%A6%E3%83%8B%E3%82%BF%E3%83%AA%E3%83%BC%E3%83%86%E3%82%B9%E3%83%88%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%AF%E3%80%81%E3%82%A8%E3%83%B3%E3%83%89%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E5%90%91%E3%81%91%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A8%E3%81%97%E3%81%A6%E8%A8%AD%E8%A8%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E6%9C%AC%E5%BD%93%E3%81%AB%E4%BD%95%E3%82%92%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%92%E7%9F%A5%E3%82%89%E3%81%AA%E3%81%84%E9%99%90%E3%82%8A%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ESCardEstablishContext%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%20%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3ESCardIsValidContext%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%20%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3ESCardIsValidContext%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%20%3A%20%E3%83%8F%E3%83%B3%E3%83%89%E3%83%AB%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%A7%E3%81%99%E3%80%82(%E6%85%8C%E3%81%A6%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84)%3CBR%20%2F%3ETesting%20SCardListReaderGroups%20%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%82%B0%E3%83%AB%E3%83%BC%E3%83%9701%3ASCard%24DefaultReaders%3CBR%20%2F%3ESCardFreeMemory%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%20%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3ESCardListReaders%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%20%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3ESCardListReaders%20%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%20%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC01%3APN7462%20USB%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC(1.00)00%2000%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_10.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_10.png%22%20style%3D%22width%3A%20665px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64908iAA17EF5D3AED1825%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_10.png%22%20alt%3D%22pastedImage_10.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%5B%E6%B3%A8%5D%20Windows%20PC%E3%81%A7vmware%E3%83%97%E3%83%AC%E3%83%BC%E3%83%A4%E3%83%BC%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81PN7462%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92ubuntu%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E5%BF%98%E3%82%8C%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_11.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_11.png%22%20style%3D%22width%3A%20805px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F64913i1F02F1A5EFE1C558%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_11.png%22%20alt%3D%22pastedImage_11.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%81%84%E4%B8%80%E6%97%A5%E3%82%92%EF%BC%81%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EWeidong%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ANFC%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E7%94%A8%E3%81%AELinux%20CCID%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHello%20%40Wingros%20Sun%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%9F%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E6%89%8B%E9%A0%86%E3%81%8C%E6%8E%A5%E8%A7%A6%E5%BC%8F%E3%81%A8%E9%9D%9E%E6%8E%A5%E8%A7%A6%E5%BC%8F%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%A7%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%80%81%E9%80%A3%E7%B5%A1%E5%85%88%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AE%E3%81%9F%E3%82%81%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3ENeel.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1116322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3ANFC%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E7%94%A8%E3%81%AELinux%20CCID%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1116322%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81PN7462%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%82%92%E8%A9%A6%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3A%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E12280717%20hotplug_libudev.c%3A651%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%20HPEstablishUSBNotifications()%20USB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E8%BF%BD%E5%8A%A0%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%2000000084%20hotplug_libudev.c%3A297%3Aget_%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%20driver()%20VID%3A0x1FC9%E3%80%81PID%3A0x0117%E3%80%81%E3%83%91%E3%82%B9%3A%2Fdev%2Fbus%2Fusb%2F003%2F029%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E6%8E%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%2000000007%20hotplug_libudev.c%3A436%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%20HPAddDevice()%20USB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E8%BF%BD%E5%8A%A0%3APN7462%E3%82%AB%E3%83%BC%E3%83%89%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%2000000029%20readerfactory.c%3A1074%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%20RFInitializeReader()%20%2Fusr%2Flocal%2Flib%2Fpcsc%2Fdrivers%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%20ifd-ccid.bundle%2FContents%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%20Linux%2Flibccid.so%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20PN7462%20%E3%82%AB%E3%83%BC%E3%83%89%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%20(1.00)%2000%2000%20%E3%81%AE%E8%B5%B7%E5%8B%95%E3%82%92%E8%A9%A6%E3%81%BF%20%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E00000104%20readerfactory.c%3A949%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3ERFBindFunctions()%20IFD%20%E3%83%8F%E3%83%B3%E3%83%89%E3%83%A9%E3%83%BC%203.0%20%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E00000016%20ifdhandler.c%3A1965%3Ainit_driver(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E)%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%201.4.28%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E00000463%20ifdhandler.c%3A1982%3Ainit_driver(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E)%20%E3%83%AD%E3%82%B0%E3%83%AC%E3%83%99%E3%83%AB%3A%200x0003%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E00000005%20ifdhandler.c%3A1993%3Ainit_driver(%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E)%20DriverOptions%3A%200x0000%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E00000144%20ifdhandler.c%3A111%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3ECreateChannelByNameOrChannel()%20Lun%3A%200%2C%20device%3A%20usb%3A1fc9%2F0117%3Alibudev%3A0%3A%2Fdev%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3Ebus%2Fusb%2F003%2F029%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E00000011%20ccid_usb.c%3A302%3AOpenUSBByName()%20%E3%81%AE%E4%BD%BF%E7%94%A8%3A%20%2Fusr%2Flocal%2Flib%2Fpcsc%2Fdrivers%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3Eifd-ccid.bundle%2Fcontents%2Finfo.%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%E3%83%97%E3%83%AA%E3%82%B9%E3%83%88%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E00000448%20ccid_usb.c%3A320%3AOpenUSBByName()%20ifdManufacturerString%3A%20Ludovic%20Rousseau%20(%3C%2FSPAN%3E%3CA%20href%3D%22mailto%3Aludovic.rousseau%40free.fr%22%20style%3D%22color%3A%20%231155cc%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Eludovic.rousseau%40free.fr%3C%2FA%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E)%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E00000004%20ccid_usb.c%3A321%3AOpenUSBByName()%20ifdProductString%3A%20%E6%B1%8E%E7%94%A8%20CCID%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E00000002%20ccid_usb.c%3A322%3AOpenUSBByName()%20%E8%91%97%E4%BD%9C%E6%A8%A9%3A%20%E3%81%93%E3%81%AE%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AF%E3%80%81GNU%20Lesser%20General%20Public%20License%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B32.1%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF(%E3%82%AA%E3%83%97%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A7)%E3%81%9D%E3%82%8C%E4%BB%A5%E9%99%8D%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%E6%9D%A1%E9%A0%85%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E4%BF%9D%E8%AD%B7%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E00000529%20ccid_usb.c%3A656%3AOpenUSBByName()%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC%2F%E8%A3%BD%E5%93%81%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3A1FC9%2F0117(PN7462%E3%82%AB%E3%83%BC%E3%83%89%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC)%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E00000004%20ccid_usb.c%3A658%3AOpenUSBByName()%20USB%E3%83%90%E3%82%B9%2F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E4%BD%BF%E7%94%A8%3A3%2F29%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E00000002%20ccid_usb.c%3A717%3AOpenUSBByName()%20bNumDataRatesSupported%20%E3%81%AF%200%20%E3%81%A7%E3%81%99%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20%2F%3E%3CSTRONG%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23222222%3B%20font-size%3A%2012.8px%3B%22%3E00067645%20ccid_usb.c%3A849%3AWriteUSB()%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%883%2F29%EF%BC%89%3A-99%20LIBUSB_ERROR_OTHER%3C%2FSTRONG%3E%3CBR%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20%2F%3E%3CSTRONG%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23222222%3B%20font-size%3A%2012.8px%3B%22%3E00000134%20ccid_usb.c%3A849%3AWriteUSB()%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%883%2F29%EF%BC%89%3A-99%20LIBUSB_ERROR_OTHER%3C%2FSTRONG%3E%3CBR%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20%2F%3E%3CSTRONG%20style%3D%22background-color%3A%20%23ffffff%3B%20color%3A%20%23222222%3B%20font-size%3A%2012.8px%3B%22%3E00000244%20ccid_usb.c%3A888%3AReadUSB()%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%883%2F29%EF%BC%89%3A-99%20LIBUSB_ERROR_OTHER%3C%2FSTRONG%3E%3CBR%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E00000006%20ifdhandler.c%3A195%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3ECreateChannelByNameOrChannel()%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E00000023%20ccid_usb.c%3A189%3Aclose_libusb_%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3Eif_needed()%20libusb_exit%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E00000015%20readerfactory.c%3A1105%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3ERFInitializeReader()%20%E3%83%9D%E3%83%BC%E3%83%88%E3%81%AE%E3%82%AA%E3%83%BC%E3%83%97%E3%83%B3%200x200000%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(usb%3A1fc9%2F0117%3Alibudev%3A0%3A%2Fdev%2F%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3Ebus%2Fusb%2F003%2F029)%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E00000002%20readerfactory.c%3A376%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3ERFAddReader()%20PN7462%20%E3%82%AB%E3%83%BC%E3%83%89%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%20(1.00)%20%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E00000003%20readerfactory.c%3A609%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3ERFRemoveReader()%20UnrefReader()%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%83%88%3A%201%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E00000003%20readerfactory.c%3A1125%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3ERFUnInitializeReader()%20PN7462%20%E3%82%AB%E3%83%BC%E3%83%89%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%20(1.00)%2000%2000%20%E3%81%AE%E3%82%B7%E3%83%A3%E3%83%83%E3%83%88%E3%83%80%E3%82%A6%E3%83%B3%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3Ereaderfactory.c%3A986%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3ERFUnloadReader()%2000000004%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E3%82%A2%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3CBR%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%20%2F%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E00000047%20hotplug_libudev.c%3A523%3A%3C%2FSPAN%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3EHPAddDevice()%20USB%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E8%BF%BD%E5%8A%A0%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3APN7462%E3%82%AB%E3%83%BC%E3%83%89%E3%83%AA%E3%83%BC%E3%83%80%E3%83%BC%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%82%93%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%3CSPAN%20style%3D%22color%3A%20%23222222%3B%20background-color%3A%20%23ffffff%3B%20font-size%3A%2012.8px%3B%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎07-13-2017 10:55 PM
更新者:
