The code is generated using processor expert. the eeprom write on mc9s08dz60, calling iee1_setword iee1_getword is ok. the number is 0x1234, when I call iee1_getword alone. the number is 0xffff. where the problem is?
Hello
Could you help us sharing your Components Inspector configuration in Processor expert
Please Share Properties, methods and Start Adress configuration,
I'm trying to do a similar setup with:
Code Warrior v11.1
MC9S08DZ60VLH Project configuration.
Could you help us confirm if you have other components besides IEE1?
If you could share more information about your setup and where are you reading the values, if would be highly appreciated.
Best Regards, Luis
