2040875_en-US
2040875_en-US
2040875_en-US
IW612 PCM/I2S support
I am developing an embedded audio application that is using the IW612 for Bluetooth communication. The IW612 has a PCM/I2S interface - is this interface only intended for use with SCO audio, or can it be used in other cases, such as for audio streaming with A2DP?
Re: IW612 PCM/I2S support
Dear @skordal ,
>> is this interface only intended for use with SCO audio?
Yes, PCM/I2S is only used for SCO or eSCO.
>>About A2DP
UART interface is used for A2DP.
Thanks!
weidong
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-21-2025 04:31 PM
更新者:
