1735023_en-US
1735023_en-US
1735023_en-US
S32DS 2.1 How to extend license
How to extend(or renew) the S32DS license? I tried to re-install it. but I was halted on licensing.
Re: S32DS 2.1 How to extend license
Hi nxp team, my S32DS v2.2 license is about to expire, how can I renew it? The activation code is 1F6D-7D64-6C38-A53C Please help me to extend it, thanks.
Yes, It works.
But when I clicked the return button, that did not work.
Problem solved, installation succeed.
Thank you.
Hi, @kuhruhm ,
I see the problem was because the older licenses was not returned.
It should be fixed now.
Please can you try installing now using the license.
Thank you. Best regards.
-Mehul Patel
I retried as an administrator. but nothing changed.
but halted online licensing, and no log was created.
My license exp. is Oct 1, 2023
Entitlement Exp is Oct 3, 2027
Does this mean my license is active?
Hi, @kuhruhm ,
As I see in the below error in your log I think the issue is because of not running as administrator mode or not having enough permission while installation.
Your Windows user account must be a member of the administrator's group as mentioned in installation guide. https://www.nxp.com/docs/en/user-guide/S32DSPAIG.pdf
The 'Run as Administrator' option should not be used for the installation of the S32 Design Studio. If you are getting an error on Windows permissions, then you likely do not have the necessary permissions to install.
If you have issue to run as administrator mode please contact your IT department to for their assistance.
Please let us know if you are able to move further.
- Mehul Patel
My S32DS is version 2.1
I tried to install it on a new computer.
Halted online licensing and I did stop by the task manager.
c:\NXP\S32DS_Power_v2.1\_S32 Design Studio for Power Architecture Version 2.1_installation\Logs\
Has no file.
Hi, @kuhruhm ,
Please can you share the S32DS installation log from the :
C:\NXP\S32DS.3.5\_S32 Design Studio for S32 Platform 3.5_installation\Logs
Thank you.
Best regards.
- Mehul Patel
No ratings
Version history
Last update:
‎03-21-2026 02:30 AM
Updated by:
