the parameter of the AMCLIB_BemfObsrvDQ
Search instead for
dear all
when I used the module of the function AMCLIB_BemfObsrvDQ, I have some question about parameter settings
 is the Imax equal to the Iscale, and the Umax is also,
if the Imax is not  equal to the Iscale ,the parameters is wrong,beacuse  the normalization uses Iscal,
so ,Ineed your help ,thanks
I'm more focused on MCU itself, so, I want to better understand your question about AMMCLIB and after that I can ask a responsible team.
Which version of AMMCLIB do you use?
Could you, please, elaborate on what do you mean by "Imax equal to the Iscale" "the normalization uses Iscal", share some equations/ screenshots?
Which MCU do you use?
Thank you.
Diana
hello,
The MCU is MC9S12ZVM, and the document is MC9S12ZVMMCLUG
The parameter calculation in the document use Imax ,I want to make sure that if the Imax equals the Iscale?
Dong
Could you, please, clarify what do you mean by Iscale? Is it some parameter in some software?
Thank you.
Diana
