is there any difference between commutation sequence for a delta-winding BLDC and wye-winding BLDC?
3,593 次查看
shirini
Hi everyone
recently I am working on a BLDC motor which has a delta winding stator.  is there any difference between commutation sequence for a delta-winding BLDC and wye-winding BLDC?  I did not find any document for a Delta-connected motor and I can not understand commutation sequence for it. is there any one explain it for me?
标记 (2)
3,582 次查看
EdwinHz
Hello @shirini!
I found two links that could prove useful for your inquiry. The first one makes an extensive description of the Delta winding connection of a BLDC Motor, and the second one explains commutation sequencing in a lot of detail:
https://www.koreascience.or.kr/article/JAKO201520441372301.pdf
https://lucidar.me/en/actuators/commutation-for-bldc-motors/
Finally, I’ll leave an extra link that explores motor controlling with one of our Microcontrollers:
https://www.nxp.com/wcm_documents/techzones/microcontrollers-techzone/Presentations/motor.control.lp...
I hope this helps,
Edwin.
3,578 次查看
shirini
Hello
I am very grateful for your reply. the paper is very useful
