S08SU16-EVK
S08SU16-EVK
Sarunas
Hello
I want to buy S08SU16-EVK module to try play with brushless motor. I don't fnd information how need connect board kit to my PC. The document write " Real-time in-circuit debug through S08/RS08 or HCS12 BDM interface", but where can I get HCS12 BMD infertace support cable? Maybe somebody give for me advice not expencive wire which I can debug S08SU16-EVK?
vicentegomez
 You need to use and external debuger/programmer like
https://www.nxp.com/products/power-management/motor-and-solenoid-drivers/powertrain-and-engine-contr...
I hope this will help you
Sarunas
The item of Universal Multilink Development Interface is expensive. Maybe is there a cheapest way connect S08SU16-EVK to PC?
vicentegomez
Any OSBDM can be used to program the S08SU16-EVK
There are many options on the web but the cheapest one that I recommend is multilink.
Have a good day
