Hi Michal --
The variable in question appears to be BoardID. The entire message is "App: ReadValue (Board ID) done [ERROR code=0x80000116]" repeated over and over. At intervals, it changes up the variable to a bunch of others, but BoardID is the most common.
I don't see any way to set that in FREEMaster.
Possibly separate, or possibly not, I also get a "Script Error" dialog box every time I select the "Motor Idendif" tab. The box says "An error has occurred in the script on this page." Line 426, char 9 "Error:"CharArray" is undefined". Code: 0. It tries to supply a URL, but the path is too long, and it is truncated before telling me anything useful.Could this be related?
Gary
Hi Josef --
- MCUXpresso IDE V11.5.0 [Build 7232][2022-01-11]
- FreeMASTER Version 3.1.1.6
SDK is probably SDK_2.x_MKV31F512xxx12 version 2.9.0, although I also have SDK_2.x_MKV31F128xxx10 version 2.7.0 and SDK_2.x_FRDM-MKV31F installed. 512xxx12 is the only choice that generates boards on the board selection screen, but it generates boards for all three versions.
Gary
Hello Gary,
this error is not related to FreeMASTER itself, but to the MCAT control project (coded in HTML/JScript) which runs inside the FreeMASTER.
I'm moving this topic to the motor control forum and will ask my colleagues to help.
Michal
