GD3160 SPI设置
GD3160 SPI设置
YinX
自制GD3160驱动板,是否可以不设置SPI直接使用PWM控制负载
TomasVaverka
We recommend using the SPI as it is needed for safety monitoring, configuration and diagnostic reporting. For example if you get a fault, you clear the fault by reading it through SPI.
BR, Tomas
a987
This does not answer the question.  It seems you are saying that it will work without SPI, just not accessing all the features - correct?
