Control accuracy of FOC
3,224件の閲覧回数
JAC_123
Hello
       If the  PMSM uses FOC control algorithm, what is the control accuracy of its speed and torque?What is the efficiency of the motor?
4 返答(返信)
3,203件の閲覧回数
JAC_123
Thank you for your attention , but regardless of hardware, what accuracy(Speed and torque)and  efficiency can PI Control, Sliding Mode Control, Proportional Control, second order Sliding Mode observer algorithm, extended Kalman filter algorithm and high frequency signal injection respectively achieve?I just want to get a general idea of FOC.
3,216件の閲覧回数
petervlna
With FOC you can achieve very high efficiency. Of course it is dependent on HW and SW design.
There are many possibilities how to do FOC. It depends in methods you use for current measurements. (single, dual, triple shunt measurement)
Its not easy to say about accuracy. Its dependent on regulators and also capabilities of your HW desing.
Peter
3,195件の閲覧回数
JAC_123
3,188件の閲覧回数
petervlna
Well,
the answer is high.
Peter
