pwm duty cyle
pwm duty cyle
383件の閲覧回数
paul_ephraim_13
can someone explain whether the changeability of the duty cycle in the Simulink depends on the channel mode?
As for the image below should I change the PWM channel mode in configuration in order to update the duty cycle via simulink before the build process
0 返答(返信)
