mbd_s32k_get_config_param return is empty
1,227 次查看
geertvenken
Making use of NXP_MBDToolbox_S32K1xx.
In lots of .tlc files the matlab function mbd_s32k_get_config_param is used to retrieve the configuration parameters.  But the return is always empty and this results in errors in the code generation process.
As this is a .p function I can not see the content and can not judge on the cause of the error.
I tried both the config set in de model and a reference config set, but no success.
See Diagnostic view information attached:
0 回复数
