Hello lynnelee,
I'm wondering if your suggestion is to install the S32 Design Studio for Power v1.2.
If so, I have tried it but it still didn't work.
Yes, please use the compiler from the S32DS for Power 1.2 and set the variable S32DS_PA_TOOL in Path with the location where the v1.2 compiler is, sometthing like here:
And by the way, the text "系统找不到指定的路径" means that "System can not find the route".
Looking for your help.
The code generates two folders "adc_model_pnt_mbd_rtw" and "slprj". Please be sure that in the first of them you find that crt0.s file. If not, please archive the folders and attach them here.
Marius
