Using BMS based on S32K144 and MC3377xB. Change duration of TPL blocking time threshold?
917 次查看
ranulf
TPL communication as monitored by the S32K144 appears to be blocking. So, if TPL communication fails for some reason code execution on the S32K144 is stopped until a time threshold is crossed. Is there a way to change the duration of that time threshold?
893 次查看
SorinIBancila
Hello @ranulf,
In the MC33772B configuration block's tlc you can find the following define: #define BCC_COM_TIMEOUT_MS 10.
You can try to modify this value to increase/decrease the timeout.
Bancila Sorin
