Urgent Issue - S32K1 can not init MC33771C over TPL
1,219 次查看
Poley
Contributor V
Hi all,
I am facing a critical issue that the config bloack can not initialize more than 10 CMU's using TPL, all of the following CID's give status message of 3 when trying to read. I am trying to use 15 CMU's.
Can anyone provide me an exple that can definitely initialize 15 CMU's on TPL at startup?
@mariuslucianand- I could really do with your help here, this is critical and probably something small to change/test?
3 回复数
1,051 次查看
Mubinb
Hey Poley,
thanks for the reply. I am in a start phase of my project. I am trying to initialize a single CMU but have the same issue of CID giving a status message of 3 when trying to read. Did you change something in the configuration for that ?
Mubin
1,081 次查看
Mubinb
Hi Poley,
did you find a solution to your problem ? I am facing the same issue like you.
Mubin
1,070 次查看
Poley
Contributor V
Hey,
unfortunately had no solution. I had to implement a messy multiple MC33664 instance work around to read all CMU’s
