Updating compatibility MBDT to latest matlab releases
已解决
跳至解决方案
4,301 次查看
craanede
Are there plans or is there a timing available for when compatibility is extended to latest matlab releases?
I have tested the toolbox on 2021b and code generation seems to work, but external mode has issues with the template makefile macros. I was wondering if there was information about other functions that might not work in 2021b as well.
Thanks for the info in advance.
1 解答
4,218 次查看
Irina_Costachescu
Hi @craanede ,
We have not centralized such limitations in a list, and for doing this and providing a complete record, we first need to test all the MBDT for S32K1 features and functionalities on Matlab R2021b. Until then, since we cannot commit to a timeline for this update, please feel free to report to us any issues you encounter.
Thank you,
Irina
在原帖中查看解决方案
6 回复数
4,289 次查看
mariuslucianand
Hello @craanede,
Can you please tell me which platform are you using?
Marius
4,280 次查看
craanede
Hi Marius,
For Sw platform--> windows 10 64 bit, R2021b.
Right now I am using S32K1xx, but I am open to change to S32K3xx or Kv1/Kv3 if that is updated more frequently.
Dennie
4,241 次查看
Irina_Costachescu
Hi @craanede
At this moment, we cannot commit to a time frame for updating the S32K1xx toolbox to support the latest Matlab releases. However, the MBDT for S32K3xx and Kinetis cover the following Matlab versions - S32K3xx (R2020a - R2021b) and Kinetis V (R2019a - R2020b).
Irina
4,239 次查看
craanede
Hi @Irina_Costachescu
Thank you for the information.
I will look into the S32K3xx toolbox and related product.
As I have mentioned, the S32k1xx does work except for some features that use the template make file  according to my own testing. Is there perhaps a list of issues available to understand what the limitations are of S32K1xx in R2021b, so that I can try to solve it myself?
Dennie
4,219 次查看
Irina_Costachescu
Hi @craanede ,
Thank you,
Irina
4,206 次查看
craanede
Hi @Irina_Costachescu ,
I will make a separate topic to discuss the issue that I found so far.
Dennie
