Transfer/ Receive n bytes & Synchronous Transmit via SPI
2,145件の閲覧回数
SuperBeginner
Dear NXP,
I have two questions regarding SPI communication development using MBDT:
  • How can I read or write n bytes (>2 bytes)?
    I have verified that 2-byte data transmission is working fine with the packet generator using the example project "s32k3xx_spi_async_interr_ebt".
    However, when I try to transmit 4 bytes of data (0xAA 0xAB), the EVB only receives the 0xAA data.
    I know this is quite normal, but I just want to provide an example to help you better understand my issue.
  • How do I develop synchronous transmit?
    I referenced the example "s32k344_spi_sync_master_ebt" and tried to start data transmission with LPSPI2, but it doesn’t work.
    I checked the status. "SPI_SetupEB" shows 0 and "SPI_SyncTransmit" shows 1.
    I have confirmed that my hardware connections are normal, as the asynchronous example project works correctly when programmed directly.
Please help me. Thank you.
MBDT  S32K312EVB-Q172
2,058件の閲覧回数
Irina_Costachescu
Hi @SuperBeginner
I would like to point you to the following thread, as a reference to a similar use case that was approached. Could you please check if the solution provided here is suitable for your use case? https://community.nxp.com/t5/Model-Based-Design-Toolbox-MBDT/SPI-configuration-MODEL-based-design-to...
Hope this helps,
Irina
3 返答(返信)
2,070件の閲覧回数
SuperBeginner
Dear NXP,
Regarding the second question - "How do I develop synchronous transmit?", I found the answer myself.
I found this was an oversight on my part, I didn't enable SpiPhyUnitSync under the S32 Config tool.
This resulted in my SPI communication not functioning in synchronous mode.
But regarding the first question - "How can I read or write n bytes (>2 bytes)?", I still need your help.
I don't know who can help me.
Please forgive me for now tagging engineers who have helped me in the past.
Thank you.
@Irina_Costachescu  @dragostoma
2,059件の閲覧回数
Irina_Costachescu
Hi @SuperBeginner
Hope this helps,
Irina
2,046件の閲覧回数
SuperBeginner
Hi @Irina_Costachescu ,
Thank you for your reply.
You solved my problem, thanks.
%3CLINGO-SUB%20id%3D%22lingo-sub-1956107%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3En%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E8%BB%A2%E9%80%81%2F%E5%8F%97%E4%BF%A1%E3%81%A8SPI%E7%B5%8C%E7%94%B1%E3%81%AE%E5%90%8C%E6%9C%9F%E9%80%81%E4%BF%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1956107%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20NXP%2C%3C%2FP%3E%3CP%3EMBDT%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FSPI%E9%80%9A%E4%BF%A1%E3%81%AE%E9%96%8B%E7%99%BA%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%20%3CSTRONG%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E3%80%812%E3%81%A4%E3%81%AE%E8%B3%AA%E5%95%8F%3C%2FFONT%3E%3C%2FSTRONG%3E%20%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3E%3CFONT%20color%3D%22%23FF0000%22%3En%E3%83%90%E3%82%A4%E3%83%88(%26gt%3B2%E3%83%90%E3%82%A4%E3%83%88)%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%BE%E3%81%9F%E3%81%AF%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FFONT%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%80%8C%3CSTRONG%3Es32k3xx_spi_async_interr_eb%3C%2FSTRONG%3Et%E3%80%8D%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81%E3%83%91%E3%82%B1%E3%83%83%E3%83%88%E3%82%B8%E3%82%A7%E3%83%8D%E3%83%AC%E3%83%BC%E3%82%BF%E3%81%A72%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E4%BC%9D%E9%80%81%3CSTRONG%3E%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E6%A9%9F%E8%83%BD%3C%2FSTRONG%3E%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%20%3CSTRONG%3E4%E3%83%90%E3%82%A4%E3%83%88%3C%2FSTRONG%3E%20%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF(%3CSTRONG%3E0xAA%200xAB%3C%2FSTRONG%3E)%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81EVB%E3%81%AF%20%3CSTRONG%3E0xAA%3C%2FSTRONG%3E%20%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E3%81%BF%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%81%94%E3%81%8F%E6%99%AE%E9%80%9A%E3%81%AE%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E7%A7%81%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E3%82%88%E3%82%8A%E3%82%88%E3%81%8F%E7%90%86%E8%A7%A3%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E4%BE%8B%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FLI%3E%3CLI%3E%3CFONT%20color%3D%22%23FF0000%22%3E%3CSTRONG%3E%E5%90%8C%E6%9C%9F%E9%80%81%E4%BF%A1%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E9%96%8B%E7%99%BA%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSTRONG%3E%3C%2FFONT%3E%3CBR%20%2F%3E%E4%BE%8B%E3%81%AE%E3%80%8C%3CSTRONG%3Es32k344_spi_sync_master_ebt%3C%2FSTRONG%3E%E3%80%8D%E3%82%92%E5%8F%82%E8%80%83%E3%81%AB%E3%81%97%E3%81%A6%E3%80%81%20%3CSTRONG%3ELPSPI2%3C%2FSTRONG%3E%E3%81%A7%E3%83%87%E3%83%BC%E3%82%BF%E4%BC%9D%E9%80%81%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%86%E3%81%BE%E3%81%8F%E3%81%84%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CBR%20%2F%3E%E7%8A%B6%E6%B3%81%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%80%8C%3CSTRONG%3ESPI_SetupEB%3C%2FSTRONG%3E%E3%80%8D%E3%81%AF%20%3CSTRONG%3E0%3C%2FSTRONG%3E%20%E3%82%92%E7%A4%BA%E3%81%97%E3%80%81%E3%80%8C%3CSTRONG%3ESPI_SyncTransmit%3C%2FSTRONG%3E%E3%80%8D%E3%81%AF%20%3CSTRONG%3E1%3C%2FSTRONG%3E%20%E3%82%92%E7%A4%BA%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CP%3E%E9%9D%9E%E5%90%8C%E6%9C%9F%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AF%E7%9B%B4%E6%8E%A5%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%E3%81%A8%E6%AD%A3%E3%81%97%E3%81%8F%E6%A9%9F%E8%83%BD%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E6%8E%A5%E7%B6%9A%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22SPI_async_mode.PNG%22%20style%3D%22width%3A%20536px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SPI_async_mode.PNG%22%20style%3D%22width%3A%20536px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F299560i805B3BC25B2CB5A9%2Fimage-dimensions%2F536x277%3Fv%3Dv2%22%20width%3D%22536%22%20height%3D%22277%22%20role%3D%22button%22%20title%3D%22SPI_async_mode.PNG%22%20alt%3D%22SPI_async_mode.PNG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESPI_async_mode.PNG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22SPI_async_mode_freemaster.PNG%22%20style%3D%22width%3A%20543px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SPI_async_mode_freemaster.PNG%22%20style%3D%22width%3A%20543px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F299559i563E5AF0E217A5D4%2Fimage-dimensions%2F543x166%3Fv%3Dv2%22%20width%3D%22543%22%20height%3D%22166%22%20role%3D%22button%22%20title%3D%22SPI_async_mode_freemaster.PNG%22%20alt%3D%22SPI_async_mode_freemaster.PNG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESPI_async_mode_freemaster.PNG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E3%81%A9%E3%81%86%E3%81%9E%E6%89%8B%E3%82%92%E8%B2%B8%E3%81%97%E3%81%A6%E4%B8%8B%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FMBDT%2Fpd-p%2FMBDT%22%20class%3D%22lia-product-mention%22%20data-product%3D%222259-1%22%20target%3D%22_blank%22%3EMBDT%3C%2FA%3E%26nbsp%3B%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fc-pwmxy87654%2FS32K312EVB-Q172%2Fpd-p%2FS32K312EVB-Q172%22%20class%3D%22lia-product-mention%22%20data-product%3D%223493-1%22%20target%3D%22_blank%22%3E%E3%81%AES32K312EVB-Q172%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1958514%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20n%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E8%BB%A2%E9%80%81%2F%E5%8F%97%E4%BF%A1%E3%81%A8SPI%E7%B5%8C%E7%94%B1%E3%81%AE%E5%90%8C%E6%9C%9F%E9%80%81%E4%BF%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1958514%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F100054%22%20target%3D%22_blank%22%3E%40Irina_Costachescu%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%94%E8%BF%94%E4%BF%A1%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AF%E7%A7%81%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1958406%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20n%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E8%BB%A2%E9%80%81%2F%E5%8F%97%E4%BF%A1%E3%81%A8SPI%E7%B5%8C%E7%94%B1%E3%81%AE%E5%90%8C%E6%9C%9F%E9%80%81%E4%BF%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1958406%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F239656%22%20target%3D%22_blank%22%3E%40SuperBeginner%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%AF%E3%80%81%E3%82%A2%E3%83%97%E3%83%AD%E3%83%BC%E3%83%81%E3%81%95%E3%82%8C%E3%81%9F%E5%90%8C%E6%A7%98%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%B8%E3%81%AE%E5%8F%82%E7%85%A7%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%82%92%E6%8C%87%E3%81%97%E7%A4%BA%E3%81%97%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%93%E3%81%A7%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%A6%E3%83%BC%E3%82%B9%E3%82%B1%E3%83%BC%E3%82%B9%E3%81%AB%E9%81%A9%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FModel-Based-Design-Toolbox-MBDT%2FSPI-configuration-MODEL-based-design-tool-box-32-bit-instruction%2Fm-p%2F1384476%22%20target%3D%22_self%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FModel-Based-Design-Toolbox-MBDT%2FSPI-configuration-MODEL-based-design-tool-box-32-bit-instruction%2Fm-p%2F1384476%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%8A%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A6%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EIrina%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1958392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20n%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E8%BB%A2%E9%80%81%2F%E5%8F%97%E4%BF%A1%E3%81%A8SPI%E7%B5%8C%E7%94%B1%E3%81%AE%E5%90%8C%E6%9C%9F%E9%80%81%E4%BF%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1958392%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDear%20NXP%2C%3C%2FP%3E%3CP%3E2%E7%95%AA%E7%9B%AE%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%80%8C%3CFONT%20color%3D%22%23FF0000%22%3E%3CSTRONG%3E%E5%90%8C%E6%9C%9F%E4%BC%9D%E9%80%81%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E9%96%8B%E7%99%BA%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FSTRONG%3E%3C%2FFONT%3E%22%2C%E3%81%9D%E3%81%AE%E7%AD%94%E3%81%88%E3%81%AF%E7%A7%81%E8%87%AA%E8%BA%AB%E3%81%A7%E8%A6%8B%E3%81%A4%E3%81%91%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E7%A7%81%E3%81%AE%E8%A6%8B%E8%90%BD%E3%81%A8%E3%81%97%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%81%E7%A7%81%E3%81%AFS32Config%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A7%3CSTRONG%3E%3CFONT%20color%3D%22%23FF0000%22%3E%20SpiPhyUnitSync%3C%2FFONT%3E%3C%2FSTRONG%3E%20%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22SPI_Setting_1.PNG%22%20style%3D%22width%3A%20384px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SPI_Setting_1.PNG%22%20style%3D%22width%3A%20384px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F300251i7F530B191A0F1210%2Fimage-dimensions%2F384x503%3Fv%3Dv2%22%20width%3D%22384%22%20height%3D%22503%22%20role%3D%22button%22%20title%3D%22SPI_Setting_1.PNG%22%20alt%3D%22SPI_Setting_1.PNG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESPI_Setting_1.PNG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22SPI_Setting_2.PNG%22%20style%3D%22width%3A%20385px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22SPI_Setting_2.PNG%22%20style%3D%22width%3A%20385px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F300250iE7EA56F719338A74%2Fimage-dimensions%2F385x247%3Fv%3Dv2%22%20width%3D%22385%22%20height%3D%22247%22%20role%3D%22button%22%20title%3D%22SPI_Setting_2.PNG%22%20alt%3D%22SPI_Setting_2.PNG%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESPI_Setting_2.PNG%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81SPI%E9%80%9A%E4%BF%A1%E3%81%8C%E5%90%8C%E6%9C%9F%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E6%9C%80%E5%88%9D%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%80%8C%3CSTRONG%3E%3CFONT%20color%3D%22%23FF0000%22%3En%E3%83%90%E3%82%A4%E3%83%88(%26gt%3B2%E3%83%90%E3%82%A4%E3%83%88)%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%AA%AD%E3%81%BF%E6%9B%B8%E3%81%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%E3%80%8D%3C%2FFONT%3E%3C%2FSTRONG%3E%22%2C%E3%81%BE%E3%81%A0%E5%90%9B%E3%81%AE%E5%8A%9B%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A0%E3%80%82%3C%2FP%3E%3CP%3E%E8%AA%B0%E3%81%8C%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%82%8C%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E9%81%8E%E5%8E%BB%E3%81%AB%E7%A7%81%E3%82%92%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%9F%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%8B%E3%82%A2%E3%82%92%E3%82%BF%E3%82%B0%E4%BB%98%E3%81%91%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%94%E5%AE%B9%E8%B5%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F100054%22%20target%3D%22_blank%22%3E%3CFONT%3E%40Irina_Costachescu%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F199423%22%20target%3D%22_blank%22%3E%3CFONT%3E%40dragostoma%3C%2FFONT%3E%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
