Problem with MBDT S32K3XX Example for CAN receive
990 次查看
anagha12
Can someone please help to run the CAN_receive model attached below. I am unable to run the model even though CAN msg is getting received DIO is not getting ON indicating CAN frame has been received.
Also in the code generated, CANIF_RX_Indication function has not been called anywhere in the code getting generated.
962 次查看
Irina_Costachescu
Hi @anagha12
Unfortunately I am not able to find the attachment of this post. Could you please check the information provided in this thread?
https://community.nxp.com/t5/Model-Based-Design-Toolbox-MBDT/Configuration-of-CAN-for-S32K344/m-p/17...
Thank you,
Irina
