No valide license file has been found
已解决
跳至解决方案
1,736 次查看
OPSofiane
I have installed Model-Based Design Toolbox for S32 SPT 3.x 1.7.0 using installaiton guide. when I clicked on verify Radar tbx license I got no valide licence.
I generate the licence using Disk Serial Numbe
Thank you for the support
Sofiane
1 解答
1,688 次查看
OPSofiane
Hello @iulianbulancea,
Thanks for the suggestion.
I solved the problem by regenerating a new license.
Sofiane
在原帖中查看解决方案
2 回复数
1,689 次查看
OPSofiane
Sofiane
1,726 次查看
iulianbulancea
Hello @OPSofiane ,
We had some problems with license checking for the 1.7.0 release. Can you try to install the patch found here. If you have any problems, please contact us back.
Kind regards,
Iulian Bulancea
