I have installed Model-Based Design Toolbox for S32 SPT 3.x 1.7.0 using installaiton guide. when I clicked on verify Radar tbx license I got no valide licence.
I generate the licence using Disk Serial Numbe
Thank you for the support
Sofiane
Solved! Go to Solution.
Hello @iulianbulancea,
Thanks for the suggestion.
I solved the problem by regenerating a new license.
Sofiane
Sofiane
Hello @OPSofiane ,
We had some problems with license checking for the 1.7.0 release. Can you try to install the patch found here. If you have any problems, please contact us back.
Kind regards,
Iulian Bulancea
