MBDT S32K1XX how to generate a continous SPI clock signal?
ErwinR
We are trying to activate a TLE8718SA Low-Side Switch with a 32K144 controller through SPI communication. In order for the Low-Side switch to listen to commands, the clock signal has to be sent continously. In MBDT's for other devices it is visible that the SPI configuration window has a "continous clock" option yet for the S32K1XX MBDT there is no such option. Is it possible to send a continous SPI clock in a different way for this device?
Tags (2)
