LS2088 Reboot issue
LS2088 Reboot issue
1,935 次查看
ranga_yn
Hello NXP,
when I give the reboot command on LS2088 board with SD boot option  - having LSDK 1906 .I am seeing the board is not restarted and it freezes . Need to give the hard boot and this is not consistent  , what may be the debug or how can I resolve the same.
Any alternate command for reboot which make the board to reboot and I can get the U boot prompt in minicom.
I am using the LSDK images same provided by NXP website.
and by nor image LS2088 is 10.10 .
logs.
[  OK  ] Reached target Shutdown.
[  OK  ] Reached target Final Step.
         Starting Reboot...
[   38.157423] watchdog: watchdog0: watchdog did not stop!
[   38.872505] reboot: Restarting system
ranga
1,848 次查看
mariuslucianand
Hello ranga.yn@radisys.com‌,
This community space does not cover the topic you need assistance on. Please create a new thread on the https://community.nxp.com/community/qoriq/layerscape  space or new NXP support case according to the following procedure: https://community.nxp.com/docs/DOC-329745
Hope this helps,
Marius
