How to configure this CAN transceiver chip TJA1145A S32K3 MBDT?
300件の閲覧回数
Texhy
How to configure this CAN transceiver chip TJA1145A S32K3 MBDT?Have any engineers configured TJA1145A on MBDT?
278件の閲覧回数
SorinIBancila
One example of the TJA1145 initialization can be found in the MBD Toolbox for BMS, which you can download and install for free. Please note that the MBD Toolbox for BMS works only with MBD Toolbox for S32K3 version 1.4.0.
However, I attached a few imagines of the initialization part for the TJA1145, but also for the SPI configuration. Make sure you follow the schematic for your board, so you initialize the correct SPI instance and properly select the chip select pin.
Sorin Bancila
