Freemaster on CAN with other CAN blocks
824 次查看
gmud1234
Is it possible to use Freemaster on CAN, and use the CAN Tx & Rx blocks on the same bus, from within Simulink ?
(our target ECU has no usb/uart interface - just CAN). I am using v4.2 of the MBDT
778 次查看
gmud1234
Thanks for the response.
783 次查看
SorinIBancila
Hello @gmud1234,
Unfortunately, you can't use the same CAN instance for Freemaster and Tx & Rx blocks. If your hardware allows it, you can use one CAN instance for Freemaster and another instance for sending/receiving CAN messages.
Bancila Sorin
