FREEMASTER 3.1 value error(MBDT)
1,140 次查看
jackie_YYY
I am using the S32K3XX freemaster example (the target board is S32K312)
The freemaster example of MBDT can be successfully compiled into the microcontroller
But the value of the variable never change
the pictures  are the freemaster setting.
Please help me check what is going wrong.
微信图片_20240414112714.png微信图片_20240414112813.png7123f6a98e640990e2a48c731a69656.png7dcc8b4e5329b1b6b968d606b681915.pngd555d87f1b2194c55e0f3fa03f37f3c.pngb5e5a28262b8f63bde2d413ecb2428b.png
1,092 次查看
Irina_Costachescu
Hello @jackie_YYY
Inside your FreeMASTER project you should use the serial communication for connecting to the running on target application.
Could you please check the following article (link)? It describes how to use FreeMASTER with MBDT for S32K3, providing details on the blocks functionalities, operating modes, and a demo example on how to inspect variables in your project.
Let us know if this helps,
Irina
1,093 次查看
Irina_Costachescu
Hello @jackie_YYY
Irina
1,061 次查看
jackie_YYY
Thanks for the reply,  I've had success with freemaster using the serial port .@Irina_Costachescu
