Hello:
When i do the operating flash from file in the S32IDE according the "Model_Based_Design_Toolbox_MPC57xx_Series_Quick_Start_Guide"
I have the following error :"MPC5744P Device detected.
Interrupt command received. Halting execution.
No breakpoints currently set.
Disconnected from "127.0.0.1" via 127.0.0.1. Disconnection by port "55541" from 7224
Target Disconnected."
Does anyone know why?Thank you.
Do we have a solution for this?
sorry , i still haven't solved this problem.
Is this solved? Which is the solution?
Thank you!
