Debug on Matlab Simulink
2,294 次查看
viktor1
Hello all
I use a S32K144 and can flash the example codes via embedded coder. Is it also possible to debug step by step in Matlab Simulink? If so how does that work?
Thank you
Viktor
2,261 次查看
gzleng
simulink external mode may support step by step debug. but the most direct way is to export to s32 and create a project to dive in.
2,269 次查看
stefancinipeanu
Hello, @viktor1
Sorry for our late answer.
Unfortunately, debugging code from MATLAB or Simulink that runs directly on an embedded NXP target is not possible. For debugging the generated code, you could use the S32 Design Studio for ARM, by taking the generated elf file from Simulink and selecting it in a S32DS debugging project.
Stefan.
