Changing the channel on the Dio block does not change the generated code.
已解决
跳至解决方案
1,111 次查看
Automan
I am using the s32k3xx_dio_s32ct example have found that if you change the Channel i any of the Dio blocks that the generated code continues to use the original channel. I tried deleting and re-adding a Dio block and connecting to a different channel sometimes works, but not always.
1 解答
1,090 次查看
robertv
Hello @Automan ,
The behavior you are describing is happening because changing the Channel/Pin inside the Dio mask is not causing Simulink to regenerate the code. We are looking into ways to improve this specific scenario and make it as hassle-free as possible.
For now, the best course of action in your specific use case, and to always get consistent results, would be to delete the "modelName_ert_rtw" folder and the "modelName.slxc" file before building the model. Doing so will trigger the code generation and update the executable based on the current state of the model. This should not be needed if the model is changed in a more significant way, like adding blocks, changing signals and/or connections, etc.
Robert V
在原帖中查看解决方案
3 回复数
1,091 次查看
robertv
Hello @Automan ,
Robert V
1,077 次查看
Automan
Hi Robert,
Is there a list somewhere that shows the current issues and workarounds for the MBDT version 1.6.0?
1,063 次查看
robertv
Hello @Automan ,
On every release, we update the list of limitations and known issues. This list can be found inside the readme.txt file located in the root of the Toolbox.
Robert V
%3CLINGO-SUB%20id%3D%22lingo-sub-2060701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%9B%B4%E6%94%B9%20Dio%20%E5%9D%97%E4%B8%8A%E7%9A%84%E9%80%9A%E9%81%93%E4%B8%8D%E4%BC%9A%E6%94%B9%E5%8F%98%E7%94%9F%E6%88%90%E7%9A%84%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2060701%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20s32k3xx_dio_s32ct%20%E7%A4%BA%E4%BE%8B%E5%8F%91%E7%8E%B0%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%82%A8%E6%9B%B4%E6%94%B9%E4%BB%BB%E4%BD%95%20Dio%20%E5%9D%97%E7%9A%84%E9%80%9A%E9%81%93%20i%EF%BC%8C%E5%88%99%E7%94%9F%E6%88%90%E7%9A%84%E4%BB%A3%E7%A0%81%E5%B0%86%E7%BB%A7%E7%BB%AD%E4%BD%BF%E7%94%A8%E5%8E%9F%E5%A7%8B%E9%80%9A%E9%81%93%E3%80%82%E6%88%91%E5%B0%9D%E8%AF%95%E5%88%A0%E9%99%A4%E5%B9%B6%E9%87%8D%E6%96%B0%E6%B7%BB%E5%8A%A0%20Dio%20%E5%9D%97%E5%B9%B6%E8%BF%9E%E6%8E%A5%E5%88%B0%E4%B8%8D%E5%90%8C%E7%9A%84%E9%80%9A%E9%81%93%EF%BC%8C%E6%9C%89%E6%97%B6%E5%8F%AF%E8%A1%8C%EF%BC%8C%E4%BD%86%E5%B9%B6%E9%9D%9E%E6%80%BB%E6%98%AF%E5%A6%82%E6%AD%A4%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2061438%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E6%9B%B4%E6%94%B9%20Dio%20%E5%9D%97%E4%B8%8A%E7%9A%84%E9%80%9A%E9%81%93%E4%B8%8D%E4%BC%9A%E6%94%B9%E5%8F%98%E7%94%9F%E6%88%90%E7%9A%84%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2061438%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%97%A8%EF%BC%8C%E7%BD%97%E4%BC%AF%E7%89%B9%EF%BC%8C%3CBR%20%2F%3E%E6%98%AF%E5%90%A6%E6%9C%89%E4%B8%80%E4%B8%AA%E5%88%97%E8%A1%A8%E6%98%BE%E7%A4%BA%20MBDT%20%E7%89%88%E6%9C%AC%201.6.0%20%E7%9A%84%E5%BD%93%E5%89%8D%E9%97%AE%E9%A2%98%E5%92%8C%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%EF%BC%9F%3C%2FLINGO-BODY%3E
