Can't get the toolbox to generate the application files
1,100 次查看
sunweiqi
Hello!I want to use Matlab/simulink to generate a project which can be opened by S32 Design Studio for Power v1.2.
I have finished all the step of Hotfix 4 and have seen "Generate S32 Design Studio ProjectInfo.xml file" option, but there aren't xml-type files or elf-type files. I also reset the Matlab but it still doesn't work. How can I do ?
Looking forward to a reply from you.Thanks!
1 回复
953 次查看
Daniel_Popa
Hi sunweiqi‌,
This might be an indication of a silent crash on MATLAB. Can you please check if there is any build exception file generated. Here is a tip how to check it: https://community.nxp.com/message/899759#comment-902087
