Can IMXRT1064 be an EtherCAT slave?
2,912 次查看
hayaoki7
Hello
I would like to use IMXRT1064 to control the motor with EtherCAT slave. Is it possible?
Hayaoki7
2,667 次查看
Dorne
Does NXP have a single-chip MCU R&D plan or roadmap integrating EtherCAT slave, like TI 28388?
Dorne
2,891 次查看
nxa11767
Hi @hayaoki7 ,
I think it can be done but you'll need to use custom code in your simulink model for the EtherCAT integration. (since there is no support in SDK API for this).
Here is an example on how to use custom code in your Simulink model: https://community.nxp.com/t5/NXP-Model-Based-Design-Tools/How-to-use-your-own-C-code-in-our-Toolbox-...
Also, here is a post on IMXRt1060-evk, trying to connect a LAN9252 EtherCAT Slave Controller: https://community.nxp.com/t5/i-MX-Processors/SQI-protocol-on-i-MX-RT1060-FlexSPI-and-memory-mapped-a...
Alexandra
2,876 次查看
hayaoki7
Hello
I'm checking LAN9252.
Thank you very much.
Hayaoki7
