C_LST in s32k144 closed loop example
964 次查看
Sriram
In the simulink s32k144 pmsm closed loop example, fast loop sampling time C_LST is used in the speed calculation (0.001) .It is 100us by default. Is this time related to the switching frequency as the fsw for the model is 10kHz. If i am using 20khz as switching freq should i change the C_LST to (0.00005) 50us ?
Thank you
标记 (1)
938 次查看
Sriram
Hello is there any update for this query
Thank you
