weston login not accepting keyboard input using oled(/dev/fb0)
terry1
1. login prompt missing from oled ( /dev/fb0)
2. weston --tty=1 --use-gal2d=1 --use-gl=0 --device=/dev/fb0   -- causes login prompt on the oled(/dev/fb0)
3. no input seen from the usb wireless keyboard.
4. I downloaded and compiled Tslib.
5. from the console run ts_test_mt
6. use touch screen to terminate ts_test_mt
7. login prompt now accepts keyboard input.
8. any clue what I should chase down for NSP? What is causing getty to get keyboard input?
Terry
danielchen
Hi Terry:
Could you please let me know your hardware and software info?
terry1
imx8mqevk with 4.14
Bio_TICFSL
Hello Terry,
By default, weston uses fb0 frame buffer for display,  I don't know what is /dev/db0,  your display frame buffer device?
there should be no use-gal2d option in weston,  it has use-g2d option.
Sorry, I am not quite understand what you are doing from step3-7.  I am not clear how to enable your keyboard and touch screen on your device.  I guess you might need to install  what need to be installed.
