"No rule to make target ..... MQX-3.6.2/lib/m52259evb.cw10/mqx/intflash.lcf needed by moo.elf
已解决
跳至解决方案
1,853 次查看
dhlocker
Well, of course not, it's a source file. This is a new MQX project - all compiles fine, Eclipse/CW10 workspace is separate from MQX-3.6.2 installation directory. Looking at the makefile doesn't help - moo.elf depends on intflash.lcf and the rest of my source files. I'm feeling pretty stupid right about now - I never had this kind of trouble with hand-built makefiles, but that was a few years ago. Regards, Donald.
1 解答
1,320 次查看
dhlocker
Answering my own question, in case anyone else might need the info eventually. Project->Clean and all is well.
在原帖中查看解决方案
2 回复数
1,321 次查看
dhlocker
1,320 次查看
c_dawg
When using MQX, it also helps when the psp and bsp compile correctly "without errors" before compiling the project using them.
:smileyhappy:This was my obvious problem.
