ping timeout for MQX 4.2 on Tower board K70F120M
ravindragurjar
I am using MQX 4.2 on a Tower board K70F120M. I see that 1 out of 10 ping requests sent to the tower board are getting timed out on consistent basis. Has anyone seen this behavior?
DavidS
Hi Ravindra,
When I have had Ethernet issues with MQX and Tower kits it usually has been a jumper setting issue.
Please review following document:
C:\Freescale\Freescale_MQX_4_2\doc\MQX_Getting_Started.pdf
Page 50 has the TWR-K70+TWR-SER jumper configuration MQX expects.
The K70 uses the Ethernet clock source from the TWR-SER card to clock both K70 and Ethernet PHY.  This synchronizes the two clock domains.  If they are not synchronized Ethernet issues arise.
David
DavidS
Hi Ravindra,
David
ravindragurjar
That helped. I no more see the ping timeouts after fixing the J18 settings.
Thank you very much. :smileyhappy:
