I need to modify the linker file. I am trying to modify an example project in MQX 4.2 using KDS to run with KBOOT (uTasker serial loader)
I found intflash.ld, modified it, but when I build the project, KDS created a new intflash.ld file that is the same as the original.
Thanks in advance,
Tom
