I have changed the port and pin code directly into init_gpio.c: _bsp_serial_io_init().
I think that MQX-team has designed that the file init_gpio.c contains HW-dependant code,
which should be tailored to suitable for own HW.
Remove also the switch-cases for dev_num/ports which are not included in your HW.
~Mark
